Question about NorStar CallPilot 100
How does a caller transfer from the General Delivery mailbox to another extension on a Norstar Call Pilot?
5 Suggested Answers
SOURCE:
TallBourbon
  • 30 Answers
SOURCE: how to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
Posted on Jan 07, 2009
SOURCE: Unable to add voicemail box on Norstar system
If the mailbox is made, you need to check the programming under sets, FWD no answer, that needs to forward to the extension on the voicemail.
Posted on Jun 08, 2009
SOURCE: Hello. I am trying
They will be the same as the Extension number. Or should be, if the tech installed it correctly.
Posted on Jul 02, 2009
  • 277 Answers
SOURCE: Can't access the General Delivery Mailbox
To retrieve message from mailbox behind the phone:
Feature 981
Enter your password as asked
To retrieve message from mailbox that is not behind the phone:
Feature 981
Press OTHER
Log = Your ext # and password together
Press OK
Example if mailbox 100 and password 1234 then your log = 1001234
Example if mailbox 221 and password 5678 then your log = 2215678
Posted on Oct 19, 2012
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Feature 981
Feature 981
Press OTHER
Press OK
Oct 15, 2012 | NorStar M7310 Corded Phone
How to transfer a call to voice mail from reception phone
press feature 986 and the extension number. The caller will be transfered directly to the extensions mailbox.
Dec 02, 2010 | NorStar M7310 Corded Phone
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
Mar 16, 2010 | NorStar M7324 Telephone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
My phone on our Norstar system rings & rings & never goes to voicemail. Other sets on this system ring 4 times & then automatically go to voicemail. How do I cjange my set?
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
May 08, 2009 | NorStar Startalk Flash 2 Phone
Help finding out what my general mailbox number
Ok, first of all the general Mailbox is 100 for 3 digit extensions or 10 of 2 digit extensions.
How to Change a Mailbox Password
1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Apr 07, 2009 | NorStar T7316E Telephone
Deleted mail box and tried to add same mail box-stating already
The general delivery mailbox might be attached to the extension. Check mailbox 100 to see which extension is attached to it.
Mar 24, 2009 | NorStar M7324 Telephone
How to chg a norstar mailbox from 'General Delivery' to 'User'
Jan 07, 2009 | NorStar T7208 Corded Phone
My General Delivery password is invalid.
Normal 0 To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
then
Normal 0 2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
Aug 26, 2008 | NorStar M7310 Corded Phone
NorStar CallPilot 100 Logo
157 people viewed this question
Top NorStar Computers & Internet Experts
Alun Cox
Vincent_G
Vincent_G
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
