I need help getting my skeletons are to move it was working fine after 2 years and I turned it on this year and its not waving and the ghost isn't coming up right it just comes up a bit but not as much as it should.
SOURCE: my gemmy brand light show christmas tree not working........
When you press the reset button on the controller box, then you need to press the small recessed button on the back of the remote control. You'll need a pen to get in there, or better yet a paper clip. That will reset the remote.
SOURCE: Airblown inflatable santa train. It will not
I installed my outdoor christmas lights, they lite up fine and about an hour later they stopped working
SOURCE: I have a gemmy michael
It sounds like either the arm disconnected from the gear,or it is a plastic gear which has been stripped.There may be a simple clipring holding the arm to the gear which has popped off also.It would look like about a half circle which may have a couple of tabs on it to be able to open it wide enough to remove or put back on.Is there any way to access it that you can find?The front half and back half may be screwed or clipped together,it sounds like how it would be built anyhow.If you can get to it,you should have either answer just by being able to see it.Just make sure it is unplugged while working on it.Do not just turn it off.Once you find something,try to do whatever it takes(should be one of the above suggestions),then plug it in and turn it on to check it.Good luck! Greg
SOURCE: need fan motor for gemmy
Hi, unfortunately Gemmy Industries does not sell replacement motors for their inflatable products. However, motors can be purchased at www.holidayinflatablestore.com. Although Gemmy cannot provide any support to assist you in the process, Gemmy understand that collectors of the product have been able to take care of their replacement needs by purchasing older, inexpensive units from E-bay and then transferring the parts to the newer model.
SOURCE: need light bulb for Gemmy 6ft inflatable carousel
we buy ours at menards,4pack for .98 cents.
