SOURCE: UNBLOCK MY PUK CODE
Your PUK code is blocked...U must have entered wrong PUK thrice...To unlock cal ur service provider a get a new PUK code..cal to ur service provider from some other phone...dey will ask ur sim no...
SOURCE: samsung e250 - blocked number
You will need to delete the saved text out of the Blocked List. In menu you need to look for Block List, i believe on that model it is found under text messages? (varies on model) If its not visible in messages look in menu>messages>settings. It may also be found in 'calls' part of the menu. Once you find list open it and you should see a list of numbers? Select the number and delete. You should now be able to receive from those numbers?
SOURCE: I buy a blocked iphone 3GS ... how can i unblocked it?
www.cellular-freedom.com
usa based company can unblock your phone for you.
SOURCE: I need to block someone from texting me.
There are no ways at all to block text messages. You can only block unwanted calls.
Sorry.
