Televison & Video Logo
A
Anonymous Posted on Oct 09, 2014
My remote from my JVC TV series SL47B-C 1080p 3D Smart LED TV 120 Hz no longer function. how to have this brand of remote control?
Series SL47B-C 1080p 3D Smart LED TV 120 Hz
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Oct 10, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002532
Points
237762
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one
5 Related Answers
Anonymous
  • 95 Answers
  • Posted on Mar 16, 2008
SOURCE: RCA universal remote
This is the eastest way to program your remote. To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
Anonymous
  • 54 Answers
  • Posted on Jan 12, 2009
SOURCE: Problem to program my remote control
Try using the guide to help you with this problemm if you dont have one, try going to a local store that sells this product.
Anonymous
  • Posted on Mar 01, 2009
SOURCE: Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Anonymous
  • Posted on Jan 10, 2010
http://resources.jvc.com/Resources/00/00/99/82841ien.pdf
Anonymous
  • 21 Answers
  • Posted on Feb 06, 2011
SOURCE: I Have a Thomson Universal
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/thomson/roc3205-manual.zip&area=other
Samsung 6400 3d 55 settings
SAMSUNG series 6 6400 User Manual Download the user manual to this TV by this site. It has all details.
Electro help
I WONT TO ADD THE CODE
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
WHERE DO I WRITE MY LED SMART TV CODE, IN ORDER TO HAVE THE SCREEM AUTOMATICALLY SET FOR FACEBOOK?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Need Motorola cable box DCT2224 code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Try this link too
Lenovo ideapad z570 wont connect via hdmi to lg smart tv
I don't think the system is compatible with the TV it can't read the pad through the HDMI port only the RGB port.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
