It will not send faxes. The fax test says everything is ok but it will not send faxes
SOURCE: HP L7680 All in one will not send faxes from PC S/W interface
After much thrashing, here is the solution to the problem. Somehow the printer drivers lost coordination
with the corresponding Windows supporting programs. You would think that reinstalling the printer
drivers would fix the problem, AND IT DOES, but there are 3 tricks:
Uninstall everything associated with this
printer with the install disk in the
computer (this may really not be necessary, but it worked for me). [This is also the solution when the a window
comes up asking for TrayApp to be inserted using a disk—they mean the hp
install disk].
After the un-install, MAKE SURE you ALSO delete the printer using the control panel. This is critical. If this doesn’t happen, the corresponding
Windows software is somehow hooked to the wrong thing when the reinstall
happens. Then reboot the system.
Install the new drivers with the printer off, and the USB disconnected
from the printer. Reboot the system [not
sure the reboot is necessary]. After the
computer has booted, connect the USB, and power up the printer. The computer will recognize the printer and
put the printer icon in the Control Panel.
It turns out that correcting the driver mis-coordination by
BOTH uninstalling the printer drivers and
taking the printer out of the control panel, then properly reinstalling
solves BOTH the fax problem, and the protection fault problem! Amazing such a little thing can make such a
difference!
SOURCE: hp 6210 fax problems
Does a mac support this thing?
The all in one are a big problem.
They don't like Norton with windows
Linux likes them fast as a printer only.
But never heard a Mac has all in one support for all features.
SOURCE: Cannot send faxes; scanner and printer ok but fax
follow the link to solve the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669473&lc=en&dlc=en&cc=us&lang=en&product=441125
SOURCE: Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
SOURCE: I get *388 error sending faxes from hp officejet v40 over VOIP
Please check this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
Here you will se a lot explinations from hp
Has the receiver gotten faxes (from other senders) since your problem started? It sounds like the receiving fax is not answering the call. Also to determine if it's your problem or the receiver's problem send a test fax to someone else.
