Refrigerators Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Jul 04, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
Helped
48301
Points
320
Inside must have a little hole for water check is it clean,and behind must have a little dish for collecting water check is in a hose from inside fridge
Anonymous
Level 3:
  • Master 1,136 Answers
Anonymous
Master
Level 3:
Answers
1136
Questions
0
Helped
354163
Points
4025
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
2answers
My Hotpoint refrigerator drips water some times alittle and some times a lot I'm not sure where it comes from I have cleaned the rubber seal and made sure there is nothing keeping the freezer side from...
In most refrigerators there is a drip pan underneath that captures condensation and allows it to evaporate. Possibly your drip pan is missing or improperly installed so that the condensation is dripping onto the floor. Check your manual, or find one online. Usually you just have to remove the grill from the bottom of the fridge to get access to the drip pan.
Mattag PSB 2151 Side by Side Fridge/Freezer. Water is dripping out at front corner under freezer side everyday. Defrost Thermostat?
Most likely plugged up defrost drain hole. Do you see any frozen water (ice) in bottom of freezer? If so then remove lower back wall of freezer compartment and use a turkey baster with some hot water to "plunge" the defrost drain tube till the water starts to flow. Clean up excess ice and away you go!!
1helpful
Leaking water from below
May be the drip collector beneath your freezer is full causing the overflow. If it is, empty it. Else, the opening to the collector may be blocked due to ice. In that case clear the route.
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
7helpful
2answers
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
I have a lg fridge/freezer and water flows from the bottom of the freezer in two channels. What is causing water to flow? Bottom draw of freezer is frozen to the floor of the freezer compartment. Help...
You have a blocked drain hole at the bottom of the fridge put very warm water in the the drawers and remove once they un thaw then remove them and clean the drain hole in the bottom. If you need more help just post here and I will give you more informaion, also if it's got a lot of water you will have to remove the drip pan and drain it out
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
1helpful
GE Profile TBX22PC fridge water problems
hi thanks for the question you have a drain problem the drain tube from freezer to the drip pan behind and under neath the fridge you have to clean that drain sometimes you have to shut the fridge down for 24 hrs let the ice melt in the drain tube cause you cant get at it so let thaw and then clean out the drain hose thanks for your question the appliance doc
Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
