Broderbund American Greetings Creatacard Platinum 8 for PC Logo
A
Anonymous Posted on Oct 09, 2014
When a new font is begun, windows encounters a problem and shuts down, why?
ashish chauhan
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 57 Answers
  • Posted on Oct 17, 2014
ashish chauhan
Expert
Level 2:
New Friend:
Greenhorn:
Answers
57
Questions
0
Helped
6319
Points
100
Please go to control panel and check for software setting
1helpful
How do I remove fonts from The Printshop 23.1?
Windows programs install fonts in the C:\Windows\Fonts folder. The fonts in that folder are accessible by all Windows programs - including Broderbund programs. However, older versions of Print Shop and PrintMaster are designed to use ONLY *.ttf fonts . So, the only fonts that those Broderbund programs can access in the C:\Windows\Fonts folder are *.ttf fonts.
NOTE: Since both Print Shop 2.0 & 3.0 and PrintMaster 2.0, 2011 and 2012 do not access fonts from Broderbund's Core Fonts folder, the following information does not apply to those versions of Print Shop and Printmaster.
Older versions of Print Shop and PrintMaster install fonts in the C:\Program Files\Common Files\Broderbund\Core Fonts folder. The fonts installed in that folder are accessible ONLY in Broderbund programs and are NOT accessible in other Windows programs.
Some newer versions of Print Shop and PrintMaster install shortcuts for some (but not all) Broderbund fonts in the C:\Windows\Fonts folder. When shortcuts for Broderbund fonts are installed in the C:\Windows\Fonts folder, those fonts will be accessible in all Windows programs.
For all other Broderbund fonts - which don't have a shortcut in the C:\Windows\Fonts folder - the most efficient way to use those fonts in other Windows programs would be to manually install those fonts in the C:\Windows\Fonts folder.
To install Broderbund fonts into the C:\Windows\Fonts folder, do this:
WinXP & WinVista:
1. Open the C:\Windows\Fonts folder (either by going to Control Panel then clicking on 'Fonts' or by opening Windows Explorer then selecting the C:\Windows\Fonts folder)
2. When the Fonts window opens, click on 'File' in the menubar then click on 'Install New Font' in the menu that drops down.
3. When the Add Fonts window opens, click in the box next to 'Copy fonts to Font folder' (to remove the checkmark).
NOTE: When the checkmark is removed from the box next to 'Copy fonts to Font folder', the end result will be one font file in the C:\Program Files\Common Files\Broderbund\Core Fonts folder and a shortcut to that font file in the C:\Windows\Fonts folder. If the checkmark is not removed, you will end up with two identical font files - one in the C:\Program Files\Common Files\Broderbund\Core Fonts folder and one in the C:\Windows\Fonts folder. Since it's not absolutely necessary to have font files in both folders, you can save some hard drive space by making sure that the checkmark is removed from the box next to 'Copy fonts to Font folder'.
4. Using the Folders: box on the bottom left side of the Add Fonts window, navigate to the C:\Program Files\Common Files\Broderbund\Core Fonts folder. Then, double-click on the Core Fonts folder.
6. After the font names are displayed, click on the name of the font you want to install, then click on OK. After the font is installed, it should appear in the fonts lists for all of your installed software.
If you don't mind having two identical font files on your hard drive, you can install Broderbund fonts by simply copying the font file from the C:\Program Files\Common Files\Broderbund\Core Fonts folder to the C:\Windows\Fonts folder.
Windows 7:
Either simply copy the font file to the C:\Windows\Fonts folder or right click on the font file then select 'Install' from the menu that drops down.
Win98 or WinME:
WARNING: If you are using Win98 or WinME, you will want to be sure to NOT have more than 750 fonts installed in the C:\Windows\Fonts folder - because more than 750 installed fonts on Win98 or WinME can cause a multitude of problems.
How to use latha tami font in page maker
In that case please let us know the Windows OS you are using and version of Page Maker too.
If you have OTF/TTF type font, U can put here 'C:\Windows\fonts\'
If you have Type1 font, U can put here C:\Program Files\Adobe\Adobe PageMaker 7.0\Fonts\
To manually install
1.Click Start, and then click Run.
2.Type %windir%\fonts, and then click OK.
3.On the File menu, click Install New Font.
4.Click the font you want to add. To select more than one font at a time, press and hold down the CTRL key while you click each font.
5.Click to select the Copy Fonts To Fonts Folder check box. The Windows\Fonts folder is where the fonts that are included with Windows are stored.
6.Click OK.
2answers
How do I enlarge my font?
Depends on the service you use. attaching two screen caps that should help you.
Gmail
Hotmail
1helpful
2answers
Malayalam font problem in indesign
Shut down all programsand then find your font folder which is usually in C:windows\fonts or you can search your C: for the fonts folder. Once you find the fonts folder delete the malayalam font if it's in there.
Open internet explorer and go to: http://www.deepika.com/font.htm
  1. Click on "Download font" below
  2. Save font in C:\ --> Windows --> Fonts (some browsers may save the file name as a .exe extension. Add .ttf to the end of the file name mlkr0ntt_TTF. The file name should be mlkr0ntt_TTF.ttf to work)
  3. Restart your computer
Now open your adobe program and see if you can use that font.
Hope this helps! If not contact me and I can find you another solution.
I have a 2002 Lincoln LS, 2 times now while accelerating out of a stop my check engine light has begun flashing. Once while going down the highway it shutoff on its own. And once it stayed on until i shut...
Sounds like what I encountered but i got an error code I went to Auto Zone and them do a free scan for errors and it was my ignition coil and spark plugs. Good luck
Cyrillic problem ob Abby Fine Reader 8.0 Professional.
please install all the fonts . On the"stupid" computer you don't have the exact font ...Save the fonts from the wise PC and copy to the stupid one. It make it wiser . :P . Usually fonts are found in folders named "fonts". Windows, Office and Abby Reader are using large collections of fonts.
2answers
About the fonts of my laptop.
Fonts change because the are defalt with the theem but if you want to change the fonts then do a right click and select the "properties" then> "appearance"> "advanced" and from there you can change your fonts.
If you have problems then post me.
Windows media player 11 shuts down
remove and install again. Probably some issue with supporting dlls or missing files.
4answers
How to install window XP without floppy disk on asus P5RD1-VM
Hi sheikhun, just ignore windows F6 to add special SATA drivers. Install windows, when finished use your Asus CD and install missing drivers from CD. Than run windows updates.
You should not have a problem, if while in your bios your SATA drive is shown in the main menu. Than check the Boot section of bios. The boot order should be.
CDROM drive 1st. SATA drive 2nd.
Disconnect any other hard drives data cable while installing windows. When you finish installing windows & installing the drivers from the CD & windows updates you can shut down the PC & reconnect the data cables you may have disconnected.
If your bios does not see your serial ATA SATA drive than your SATA onboard controller is defective. Return to Asus for replacement/repair.
Mike
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
