Kenmore power miser 5, water only stays hot for about 5 min sometimes less......bought house last yr and water heater was fine. Problem Just started this yr..
Sounds like the down tube broke off On the cold side there is a tube that takes the cold water to the bottom of the tank and heat up to replace it . That causes it to help push up the hot water . You will need to remove the nipple bringing in the cold water and replace the tube. you can check on the tube after you remove the nipple by sticking in a finger and pulling up the remains of the tube if it was not attached to the nipple if there is nothing there same thing you need a down tube.
SOURCE: I have a rheemglas standard electric 40 gallon
You should have two panels on the front of your water heater most likely painted blue. Each of these panels contains a heating element. The top panel contains the reset switch. Unscrew and remove the top panel and you'll see the reset switch - it is the red button. Press it to see if it clicks. If so, your hot water should last longer.
If it does not last longer than you stated, then you most likely have a bad heating element. The problem is that unless you remove both elements, you won't know which one is bad. If you don't feel comfortable turning off the water valve to the heater, turning off the power to your water heater at the circuit breaker box, draining the heater of it's water using a garden hose, removing the wires from the elements, removing the elements and installing new ones from your home improvement store then you may want to hire a plumber to do it.
The process is fairly easy but time consuming. The most time is draining the water heater. If you do choose to do it yourself, you will need to get a special "wrench" from your home improvement store to remove the heating elements first. The store can help you with the element(s) you need once you take them in.
Regards
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
