SOURCE: WILL NOT PRINT COPY FROM COMPUTER TO PRINTER
To me it sounds like you may have to uninstall the printer software then reinstall it make sure mark that printer as your default printer .
SOURCE: printer keeps printing the copy over and over and over
Shut down, unhook the USB cable, turn computer on, shut down, reconnect the USB cable, turn on computer.
SOURCE: hp1320 will not print multiple copies
It seems to be an issue with the printer drivers on the computer,You need to check for any
queued documents,if they are there,if yes,delete them,if not go ahead and unintsall the printer drivers from the controlpanel>printers and faxes and then restart your computer and then try a plug and play if its a USB printer or if its a network printer check for the ip
address on the printer as well as the computer,they shuld be the same on both or it will not work,this should resolve your concern.
if you want a technician to do the entire troubleshooting for you.You may get in touch with one of the techbuddies,they offer free technical support for such issues.
you may get them at
http://tinyurl.com/m7ghqz
SOURCE: 920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
SOURCE: line on copy but not on print from computer
The problem you are having is either ink, correction fluid or something has stuck on the scanner pickup image sensor. To clear the material you will need to first open the machine to get to the sensor. To do this pull the control panel forward, it will open just a bit where you load the paper to be sent. If you look down from the top you will see the sensor glass. Use a paper towel sprayed with window clearer. You may have to gently scrub the glass to remove the blockage. You may even be able to see what is blocking the image sensor. After cleaning the glass let it dry for a few minutes before you close it and try copying or faxing.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
