Sony vaio model PCG6Q5P not working webcamera and finger print sensor. what to do. please ping me a link.
Http://www.testmycam.net/
http://noeld.com/programs.asp?cat=video
look over here
SOURCE: unlocking finger print on a sony pcg-9w3m
Sorry for your lost.
Even though it has a fingerprint lock. There should still be a password. If you know the password. Or else you will need to format and reinstall the Operating System on the computer to use it.
SOURCE: Touchpad and buttons won't click on Sony Vaio
it could be caused because of hardware failure or software failure, in case of hard ware failure it would be best to call sony tech support but in case of software issue , if you remember the day it was working fine,
do a system restore to the date it was working fine, which will reset your software configuration to the date you know it was working ok, so if it was caused by software issue it will be resolved, but any programs that you installed after the restore date will be lost
to do system restore
reboot your system when you see the sony logo start tapping the F8 key and you will come to a menu here select safe mode and boot and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts select the bold date your system was working fine and continue as it guides,
If you think the information i gave you was helpfull please do rate me
Regards
Ltoso
SOURCE: Sony Vaio PCG71212m Drivers Can't find them
Here's one possibility:http://www.drivermanager.com/en/drivers.php?Brand=Sony&Logo=sony&gclid=CMPZ4pnQ7K0CFcuP7Qod7i5j4Q
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and Driver
downloads
as required.
If Sony have no drivers then it will not work, you could try the camera manufacturers web site?
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
