SOURCE: Garmin Nuvi 200
Guys go to
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=104952
http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
they have the answers
it seems a standard or phone USB cable will not work to charge and use the maps at same time
Good luck
SOURCE: Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
SOURCE: Computer symbol when charging my Garmin Nuvi 200
TRY SWITCHING GPS OFF WHILE CONNECTED. IF NOT DOWN LOAD NEW SOFTWARE AND WHEN FINISHED IT LEAVE CONECTED SHOULD SHOW CHARGING AND YOU WILL BE ABLE TO USE
SOURCE: Garmin Nuvi 250 stuck in mass storage mode
Make sure you have the rite charger. Garmin will only work with a garmin charger. You may have accidently picked up a blackberry charger or something. Hope this helps
SOURCE: when pluggin to the car
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
