Most likely not as I don't think any Smart TV has Bluetooth capabilities to connect to input devices like mice. However you can try but it may simply not have Bluetooth or not detect the mouse.
If your TV is bluetooth enabled, yes the same as your phone or other device.
If your TV is not bluetooth enabled, yes, but only with the auxiliary cable that came with your PBT 3001. The back of your TV should have a coaxial audio out (a solitary orange audio output). Depending on your model TV, you may have to get an adapter to be able to use this output.
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
