Cant insert a CD. When I try to eject it, it just clicks. Help!!!!!
SOURCE: cd stuck
HI,
It is jammed and it will not come out of it. You have to open the cover
and manually eject the CD from it. There is no other way you can take
it out.
The best solution is to get it serviced.I hope it is still under warranty.
Goodluck..
SOURCE: CD not playing with bose wave system but same cd
The cd assembly is the issue, over a period of time the laser pickup becomes weaker until it can no longer read the disc, one possible solution is to buy a disc cleaning kit and follow instructions in an effort to recover the assembly. If that fails the only option is contact Bose for pricing since they are the only authorized service centre that work on their own products.
SOURCE: What's your problem?Bose wave system cd doesnot eject
Contact the nearest authorised service center for Bose. CD loading mechanism has been struck. You have to open it. It is a skilled work.
SOURCE: Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
It is now time to get BOSE to stand behind their product- they sure charge enough for their product. Call them and complain and don't let
them off the hook. Tell them you will place complaints against their product on the internet. I bet there are some there now.
This is why I do not buy any of their stuff.
