My scooter just quit working and when I traced the wires to the control box I saw a blinking light, the light blinks 7 times,I need help fixing this
SOURCE: Need service manual or electrical wiring diagram.
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
SOURCE: Trying to troubleshoot a shortage on my Pride
Visit:WWW.ALLDATASHEET.COM .type in your info you require in the correct boxes & you will locate it.& you will find everything you need there as it is all data.
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
SOURCE: wiring diagram for sc234ala mobility scooter
Hi. Do you need a basic wiring diagramme for the lights, motors etc. or do you need one for the controller? What faults do you have?
Fisher and Paykel sold their mobility scooter business to Plega Healthcare in Australia. Plega now no longer suport the mobility scooters.
We have some parts left in stock, and were an authorised service agent for these machines.
No one was ever supplied with a circuit diagramme for the controllers.
We do have all the service manuals here and have a full set of the fault codes.
You can email us at [email protected]
Good luck. Neil.
