Shavedice wall to wall,inclouding inside door
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Hello Wally, thanks for your post!
Based off the information you have provided you would like to know the location of the water line inside of your Frigidaire refrigerator. The water line is located within the wall of your refrigerator it is not accessible. The best way to clear out a frozen water line is to disconnect power from the refrigerator for at least two to three hours. This will help defrost any ice build-up within the refrigerator. I hope this information is helpful to you. -Matt
