Fender Passport 150 PRO Portable PA System Logo
A
Anonymous Posted on Oct 08, 2014
<!-- from fixya rte -->Why do the fuses keep blowing - Fender Passport 150 PRO Portable PA System
Thomas Beaver
Level 3:
  • Master 2,119 Answers
  • Posted on Nov 18, 2014
Thomas Beaver
Master
Level 3:
Answers
2119
Questions
0
Helped
750949
Points
6319
The obvious answer is that it is pulling too much current. The cause could be many things. First thing to look for is usually capacitors going bad followed by shorted transistors.
There no easy answers to this problem.
Often you can locate a shorted capacitor by looking for one with a bulging end or electrolite leaking.
I am looking for the proper fuse needed for this amp. I keep purchasing the wrong ones
The fuse rating should be printed on the panet right by the fuse holder. If there's still a question about values, you're best bet is to contact Crate customer service.
Here's the link-
http://www.crateamps.com/support
However, if you're meaning that you keep blowing fuses and therefor think you're instaslling the wrong value, you may have a short in the amp that's casuseing the fuses to blow. In that case, it needs to go to the shop. If you're not a tech, don't poke around inside it. You can make the problem worse, or even get a nasty shock.
2answers
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Mackie profx12 fuse keep blow
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Hammond organ c2 hook to a 147 leslie speaker it keep blow the 1.5 slo blo fuse how do I fix this
Like all the past answers, make sure everything is clean and lubricated expecially on the Lesley if it's a motorized rotating speaker, the slow blow fuse is telling you there is a problem ?
Feb 22, 2015 • Music
1helpful
2answers
Bm5a blows fuse when turned on
Blowing a fuse means that it has a dead short. The fuse does its job by protecting the other components while the circuit fails. Something is definitely burned out inside.
Mackie hr624
I suggest either replacing these OR taking them to a professional to be serviced. Fuses blowing are a sign of serious malfunction and inexperienced DIYers should not attempt to induce the Darwin Effect
One side of my peavey xr86000 power mixer blew a fusework
Any unit that blows fuses needs to be serviced. Do not keep putting in fuses only for them to be blown again. Each time you put in a fuse and it blows, it will create more damage to the amplifier.
Peavey Vyper Tube 120 keeps blowing fuse
You are either trying to: (A) push it too hard, (B) using the wrong type of fuse -- should be a "Slo-Blo" type, or (C) it has internal shorting or voltage modulation and requires service.
Jan 11, 2013 • Music
Still Blowing fuses
there could be something wrong with moisture. I had a drink spilled down the back of mine and I had to clean the board cause it kept blowing fuses.
Aug 18, 2017 • JBL EON 515
Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
