INK SYSTEM HAS FAILED. UNABLE TO PRINT
The printer's control panel displays alphanumeric code error without any additional information on the cause of the error. Carryout the steps below to resolve the issue.
Reset the printer
1. Power up the printer and wait until it is idle and silent.
2. Do not disturb the wireless connection if the printer is connected to a network.
3. If the printer is connected to your computer using a USB cable, unplug the cable from the printer's rear.
4. Remove the ink cartridges from the printer.
5. Plug the power cord out from the printer while the keeping the printer turned on.
6. After a minute, plug the power cord back to the wall outlet and into the printer's rear.
7. If the printer fails to power on automatically, press the power button to turn it on.
8. Reinstall the ink cartridges.
9. Print a calibration page if prompted.
10. Plug-in the USB cable back to the printer if you unplugged it.
11. Try to print.
Service your printer
http://ww123hp.com/
SOURCE: Ink system has failed.
The manual will say to turn it on and off and also to unplug it and hold the ok button while doing so. If this doesn't work, then go to
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&submit.y=8&submit.x=5&lang=en&cc=us
and upgrade the firmware, you will first have to select your operating system. This should then solve the problem.
If this still doesn't work, then contact hp at www.hp.com/support and click on Contact Us and go to and sign into the chat line for 24/7 tech support assistance where they will most likely run you through the same process once again but if everything they tell you fails, they will then send you a different firmware.exe file that will definitely fix your problem. Let me know if the link works or if you run into any other problems
good luck
SOURCE: error message 0xc18a0001 Ink system has failed.
Easy fix. I found elsewhere on this site that the solution is to RESET the printer via the following instructions from HP...
1) Unplug Printer
2) Simultaneously press and hold the HELP & OK buttons
3) Re-plug in printer, while still holding the two buttons.
That's it ! You are reset. It will take a little time for the printer to re-configure, but you'll be printing in 5 or so minutes.
SOURCE: hp photosmart c5180 ink system failure
Hi ok then try
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Ink System has failed. Unable to print
Hi try this
Reset the product:
5. Wait 60 seconds.
