There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
SC542, SC543, SC544,
SC546, These codes are related to fuser temperature. Make sure that
power source voltage are not low. check thermisters, fusing lamps etc. To reset
this code press "All clear" yellow key, enter 107 and press the red key for some
seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and
select "1". Then hold down the Photo mode key and the # key at the same time for
at least 3 seconds
How to detect Invisible users in G talk?
1.) Start a new chat with the intended user.
2.) Set the chat to off the record so that it doesn’t get logged to the g mail account.
3.) Send a message to the user. If the user is online and invisible, the message will be delivered.
4.) If the user is offline, you will get an error message indicating that the user is offline.
With the above mentioned four steps, you can identify if a user is invisible or is indeed offline on G talk
