Question about NordicTrack Exercise & Fitness
How do I fix a belt not working correctly
Serial #AA150110818 Model # NTL61009.0
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
If you mean the walking belt. is it slipping? if so there are two bolt at the rear of treadmill that need tightened to remove the slack in the belt
Posted on Oct 22, 2014
SOURCE:
How do I change the belt
turn the power head upside down. There should be a latch to open. the belt goes from the center of the floor brush to a piston on the motor. It helps if you have the old belt to get the correct size.
Feb 11, 2015 | Vacuums
What size belt do i need two pulley 38 inch cut
Washer belt aren't givin out on size, they are model specific. Because not only circumference but thickness and compound so use the washers model / serial number to get the correct one
Jun 01, 2014 | Samsung WF206ANS Front Load Washer
1991 Maytag dryer Model #LD 68424AAL Serial # A0190126HY
Are you sure that you hooked the belt up correctly, as it sounds like you may have missed the tensioner pulley. As this will tighten the belt around the middle of the drum
Jul 20, 2010 | Maytag Dryers
46 in yardman model OEM-190-112 I need to know the belt pattern please
If you get the correct model AND serial number off the tag under the seat, go to mtdproducts.com and you can download an owners as well as a parts manual for your tractor. One or both of them should have your diagram and routing for the belt
Oct 04, 2009 | Mtd Garden
I have a very old snapper and need a new belt. The belt that is on it is not the right one to begin with, I have the serial # and model #, I am just trying to find maybe a part # or the correct size and...
Hello.
The greatest part about owning a Snapper is that they have changed very little over the years. Your belt is one of the easiest parts to match up. With the numbers that you have, the Snapper dealer can make the match for you. It really is that easy. I have gone in with much less information, and still received the correct parts. Try it.
Best regards, --W/D--
Jul 16, 2009 | Briggs & Stratton Garden
Deck belt does not engage blades on riding tractor
Be sure the belt is the correct size and is routed correctly.
If you are not sure, you can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 18, 2009 | Oregon Scientific Electric PTO Clutch for...
Can't seem to get the correct size belt for my mower deck
The belt called for this tractor is 532 14 42-00 the belt is 1/2" wide 3/8" thick and 88 3/8" long
Nov 08, 2017 | Craftsman Garden
Turntable spinning too fast
The turntable speed is controlled by a belt, which is virtually a big rubber band. If it spinning too fast , then this means the belt is too tight. The only way this can happen is for the unit to be fitted with an incorrect size belt. You didn't say if you have a new unit, or a second-hand one, or if it has recently had the belt replaced. If it is a new unit and still under warranty, take it back to the retailer and ask them to fix it for you. Again, if you have recently had the belt replaced, take it back and ask them to do the job again, and this time to please use the correct belt. Be polite but firm....If you are a handyman, the job is not too hard to do yourself, and if you need any extra help, just ask, johnatwagga@yahoo.com. To buy the correct belt, you will need the name, model number, and preferably, the serial number. All of these can be found on the back of the unit. Good luck, and I hope this helps.
Nov 24, 2008 | Teac GF-350 CD Shelf System
Exercise & Fitness Logo
67 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Ross Metcalfe
Ross Metcalfe
Kardoc
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
