Printer shows green wifi light on but says printer not communicating with network how to fix?
SOURCE: Cannot print from network
it must be problem with security settings so give security permission to print and also check if something is blocking like Firewall and turn off the WS Firewall
SOURCE: I set up my own wireless network and now my
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
SOURCE: I've been printing on my
Hello Richard..... I had the exact same problem last week. After an hour of frustration I inserted the printer disk [the driver] and when the menu popped up I removed all lexmark info from my computer. Then I reinserted the disk and downloaded the same information once again. It works like a charm now. Joe
Thanks for choosing Fixya!
SOURCE: I get a message saying
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Unplug and re-plug the printer into the power source to reset it. Reboot your computer.
You may also refer to this article found in the Lexmark website: How to identify a Wireless Communication Problem and Resolution Tips.
SOURCE: there is a problem communicating with the printer
Please download the firmware update from the Lexmark website www.lexmark .com and install the patch http://bit.ly/pWGkeE after updating.
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
