WHAT NEEDS TO BE DONE SO THIS DOESNOT HAPPEN
SOURCE: Gmail compromised
I would advise changing your gmail password, but first, run a spyware/malware and virus scan. Running the scan first will verify that you do not have any keyloggers, trojan horses, or viruses on your computer. Then, once those are complete and your computer is deemed safe, change your gmail account password.
SOURCE: i was trying to sign up for gmail and entered the
Don't worry. You create another account and while entering your birth date make sure that your age must be over 18. If you have any further problem, please feel free to contact me.
SOURCE: my password doesn't work and i cannot sign in my gmail address
Next time, prior to changing the password, set your "password recovery options". You can enter a cell phone or alternative email address in order to assist in getting back online.
SOURCE: 2 gmail accounts one is not working, plz help
ive had a phone that had a gmail on it and now i can get in it ple help
SOURCE: Created a new gmail address and cannot access it. It says I have the wrong address or password???
Hi Cher,
Most likely, you're using the wrong password. Most times this is because you have accidentally enabled CAPS LOCK when you were creating the account, or you were using the numeric pad whilst it was disabled (hence you didn't type any numbers in the password, although you thought you were). Try to login and use the password you know but enable CAPS LOCK or disable NumLock before you type it (i.e. try replicating what your keyboard status was)
If unsuccessful, either give up the account and create a new one or try calling Google support - but keep in mind they may suspect you're trying to hack into someone's account, unless you know all the details AND you're using 2 way authentication (i.e. you have added a mobile number where you can receive an SMS with a code)
