Locks & Locksmithing Logo
A
Anonymous Posted on Oct 07, 2014
I have a 3 digit 'Design Go' combination lock which we cannot remember the code (lock is in closed position) - how do we reset it so we can use it?
Small combination lock for Travel Case
LeeMost
Level 1:
Problem Solver:
  • Contributor 26 Answers
  • Posted on Dec 04, 2014
LeeMost
Contributor
Level 1:
Problem Solver:
Answers
26
Questions
0
Helped
33740
Points
27
3 digits is only 999 combinations. You can dial each one and try it. Even if you are so slow that it takes 2 seconds per try, you'll go through all combinations in half an hour, and you'll likely find yours in ten minutes or so.
5 Related Answers
Anonymous
  • Posted on Jul 12, 2009
SOURCE: I lost the instructions to reset the combination for two luggage
I lost the combination lock
Anonymous
  • 38 Answers
  • Posted on Sep 15, 2009
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Anonymous
  • 4 Answers
  • Posted on Jun 15, 2010
SOURCE: resetting my master lock
nokia6708
Anonymous
  • 541 Answers
  • Posted on Jul 05, 2010
SOURCE: how to reset an open master lock
your answer is on this site
http://www.masterlock.com/faq/lostcombo.shtml
Anonymous
  • 28 Answers
  • Posted on Sep 01, 2010
SOURCE: My friends were messing around
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
How do you reset a lock on a hot tuna case please
Picture the scene, you've just arrived at your hotel in an unfamiliar city after a long flight. You put your suitcase on the bed and slowly turn the numbered wheels of the three-digit combination lock. You press the button to get access to your case but nothing happens. The metal zipper tags remain firmly trapped in the lock's clasp...
A locked suitcase with TSA approved combination lock
Getting locked out of your luggage is something that happens to even the most seasoned travellers at some time or another. Luckily the ubiquitous, TSA approved, 3-digit combination locks used by brands such as Samsonite, Eastpack, Antler and American Tourister are easy to open without damaging either the lock or the case and without any special tools.
By following the steps described below, you will be able to quickly open the lock and re-program the code to a new 3 digit combination which is easier to remember.
A 3-digit TSA007 combination suitcase lock
How to Unlock Your Suitcase When You Forgot the Combination If you look closely at the lock from above, you will see that to one side of the 3 numbered thumb-wheels there is a small disk (see photos below).
I have found that the best way to see the disks is by using your mobile phone's camera.
Select the video camera and shine the flash down into the lock then zoom-in to see the disks more clearly.
Starting with the first thumb-wheel of the lock, turn the wheel one click at a time until you see a notch in the disk as shown in the photos.
Once you have lined up the notch of the first wheel you then repeat the process for the second and third digit until the notches of all three wheels are lined up (see the photo of the blue suitcase).
Once all three notches are lined up, turn the suitcase so you can see the numbers.
Note, this is NOT the combination code.
The notch is not visible on either disk
Write down the numbers on the first line of a blank sheet of paper.
On the next line add 1 to each digit.
Repeat this 8 more times until you have a list of 10 3-digit numbers as shown in the photo below.
Try the codes one at a time until you find the one which opens the suitcase.
Once the case is open you can change the combination for one which is easier to remember.
With practice, the entire procedure takes less than 2 minutes.
Video: How to Quickly Open Your Suitcase Lock When You Forgot the Code
When writing this article I used 2 different suitcases, both of which are fitted with TSA approved Travel Sentry combination locks. The locks are slightly different models but the procedure is identical.
I made the video using the older, blue, suitcase because the notches in the green plastic discs are easier to see than the notches in the black disks of the red suitcase.
The code which opened the red suitcase was 2 clicks away from the position with the disks lined up. The code which opened the blue case was 8 clicks away.
If none of the codes which you have written down work you should check that you lined the notches up correctly. As can be seen in the video, there are normally two positions where the notches are visible. Make sure that all 3 notches are lined up in the same position. You can see that in the video I lined up the disks at the right-hand position.
The notch on the left disk is now visible
How do Combination Locks Work?
The 3-digit combination locks used on suitcases are designed so that you can change the combination to a unique code which only you know.
To do this, you have to first set the lock to the current combination. You then press a small button (normally using a ballpoint pen) which frees the numbered thumb-wheels from the locking mechanism (currently in the open position).
You can then turn the 3 numbered thumb wheels independently to a new combination before pushing the larger button (the one which is used to open the lock). This re-connects the numbered thumb-wheels to the locking mechanism, activating the new code.
The method described above relies on the fact that part of the locking mechanism itself is visible (the notched disks next to the thumb-wheels). This makes the number shown on the knurled thumb-wheel pretty much irrelevant. Once the disks are aligned you simply need to rotate them around until the lock opens.
The notches on all three disks are lined up
What Are TSA Approved Locks?
The TSA (Transportation Security Administration) is a US federal government agency responsible for the security of travellers that was created in response to the September 11 attacks.
All luggage is scanned before being loaded into aeroplanes and if any prohibited items are detected it will be opened by airport staff and the items removed.
TSA approved locks, identified by the red diamond shaped Travel Sentry logo, can be opened using master keys. The locks are often incorporated into suitcases but TSA approved padlocks are also available.
If your suitcase can't be opened with a master key then, if they need inspect your luggage, airport staff will open it by force, cutting off padlocks etc.
To save confusion it's a good idea to note down the numbers
In theory the keys are only available to airport staff but in reality anyone with a 3D printer can print out their own master keys.
Is it Really worth Locking my TSA approved Luggage Lock? As we have seen, the 3-digit combination locks fitted to most modern suitcases offer very little or no security. At best they stop your suitcase from opening accidentally during transit, preventing your dirty laundry from spilling out on the baggage carousel.
Some suitcases (including the red suitcase in the photos) have small metal hoops incorporated into the zip-pullers allowing you to use a padlock to lock your suitcase. Although at first glance this may seem to add a second level of security, in reality, it's a waste of time. As shown in this video, zip closure suitcases can be opened quickly and easily using a ballpoint pen.
Once the lock opens you can change it to one which you can remember
Nov 08, 2018 • Cell Phones
2answers
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Need instructions to reset kasp combination lock
I have a kask 119 series combination locke. Some clever person thought they would reset and didn't think to remember the code. What can I do to find out the code. Or reset it.
16helpful
3answers
21helpful
2answers
I don't remember the combination but it is open. please tell me how to set it
same problem with the spinner model.
My suitcase is open but since I dont have the lock combination (3 digits) I can't close it (not lock it, just close the case) . The combination changed when the case was open - is there a way to reset it ?
1helpful
How do I change the combination code for the glove box if there is not a way how would I find out what the combination is
I assume you know the current combination and can open it. To set the combination to a number code of your choice you must first remove the red plastic guard over the yellow tab next to the combination dials. Push the glove box release lever to the right to open the glove box. To change the combination:
1. With the glovebox open, hold the release to the right and slide the yellow tab up. This locks the release open and permits you to reset the code.
2.After resetting the code, write it down in case you forget it.
3. Slide the yellow tab down and the release will return to the closed position.
4. Close the glove box and move the dials off the code you set to lock it.
This is all from the 89 Pontiac Owners Manual. Good luck, hope it works.
2helpful
How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
17helpful
3answers
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
