Hello, Yes, many MB cars have security codes built into the stereo header units, including my own, (a theft deterant) You never really need to input it til you lose all battery power. If you have the orig. owners manuel it may still be in there. If not you may be able to get the code from the MB dealership using the vin number. Hope this helps a bit.
Regards,
Bill
1997 S500 owner.
SOURCE: Need Radio Code for ML320 Mercedes Benz
The main dealer will supply the code usually for a small charge.
Have a look on line first though because some are offered freely .
You will need the model year and chassis number.
SOURCE: I need a radio code for my 320ML Mercedes Benz
If your lucky the code may have been written down in the manual book and instructions on how to enter the code. If there was no codes you can try 0000 and see if that works which is the default if no security codes were programed.
If that does not work go to www.radio-code.com. I think it's like $9.00 and they can retrieve the codes for you.
Good luck and hope this helps.
SOURCE: need a radio code for a mercedes benz clk 430 2001
You can get the code from any Mercedes dealer around you. Or you can have the code by taking the radio out and take the serial to a radio repair shop and they can get the code from the serial.
SOURCE: i need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
SOURCE: 2000 mercedes benz ml 430
The 2000 Mercedes models all utilize a Shift Interlock, which will only allow the vehicle to be shifted out of Park while the brake is applied. The way this works is that a lock pin holds the shift lever in the Park position until a solenoid is powered by the brake light circuit, pulling the lock pin away from the shift linkage. The wire to the solenoid may come loose, or the brake light switch may fail. If someone tried to remove the vehicle from Park without applying the brake, the end of the lock pin may have become jammed. Try two things: 1) Start the vehicle, put your foot on the brake, and attempt to move the shift lever from Park to Reverse. 2) If you cannot remove the vehicle from Park, are the brake lights coming on? If not, a) replace the 15A fuse for the brake light circuit, and b) try Step 1 again. 3) If you cannot remove the vehicle from Park and the brake lights are coming on normally, locate the interlock solenoid at the shift lever and make sure it is properly connected. When you put your foot on the brake, the solenoid should retract. If it does not, check for 12V at the solenoid when you put your foot on the brake. If you have voltage, replace the solenoid. If you do not have voltage, you have a broken wire between the brake light switch and the solenoid. If the solenoid retracts but you still cannot remove the vehicle from Park, your shift linkage may have become bent at the transmission linkage. Hope that's helpful! :)
