galaxy shower aqua 3000 water is leaking from the back of the shower unit after the show hose was kinkedgalaxy shower aqua 3000 water is leaking from the back of the shower unit after the show hose was kinked
AnonymousMar 19, 2014
leaking from rose when offleaking from rose when off
You can't post conmments that contain an email address.
were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
check ur anti-scold setting when shipped from factory unit is set cold install instructions always advise about adjusting to suit your comfort--remove handle and using the blue & red adjustment tabs set the heat to your desired comfort
either to much water pressure to unit or pull up is clogging /damaged if u have separate valves on water supply start at half way and work ur way open or close till water doesnt come out of shower head
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
