The issue you are experiencing with your Godox X1 trigger and TT350 flash not firing when mounted on your Olympus E-M10 camera, could be related to the camera's settings or the compatibility of the trigger and flash with your camera. Here are a few things you can try:
- Make sure the trigger and flash are set to the correct channel and group: The trigger and flash should be set to the same channel and group in order for them to communicate properly.
- Check the camera's flash settings: Make sure that the camera's flash mode is set to "Wireless" or "Off-Camera" and that the flash is set to "Manual" or "TTL" mode.
- Check for firmware updates: Make sure that the trigger and flash have the latest firmware installed. This can be done through the Godox website or by using the Godox firmware update tool.
- Check the camera's hot shoe: Make sure that the camera's hot shoe is clean and free of debris. Also, check that the trigger and flash are properly connected to the hot shoe.
- Check the camera's manual: Make sure that the camera is compatible with the trigger and flash. Some cameras may have different settings or limitations that affect the use of external flashes.
If none of the above steps resolve the issue, it may be best to contact Godox customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's also important to note that some cameras have a "pre-flash" that might not be compatible with some triggers, in this case, you should use the manual flash mode to avoid this problem.
