Get error mesage after it reads disc -"incorrect disc 104". Waht does that mean?
SOURCE: Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
electech
SOURCE: Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
4)This
folder is the DVD/CD-ROM Drive Class Description in the registry.Look
for any of the following names in the right hand column.
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8)
Open My Computer and check to see if your CD or DVD drives
havereturned. You may also want to open Device Manager and verify that
theyellow exclamation and error code on the CD or DVD drive is gone.
SOURCE: HOW DO I SET THE CLOCK FOR SANSUI VRDVD4005
I believe the VRDVD4005 manual (which is the same as the VRDVD5000) is available on a Sears sponsered website called managemylife.com. I hope this helps you.
SOURCE: My DVD recorder will not recognize any of the DVDs
yes, that is the solution... try to get the DVD that is 4x (Maxell, Dynex) most are all up to 16x now... unless you can find a firmware update for Sansui (I tried already for you, but you can with out a doubt try too)
