May 8, 2006
Product : imageRUNNER C3100 / C3170
Title : E021-000x Error Code
Error : E021-000x Error Code:
Developing rotary does not rotate and abnormal noise comes from
motor.
E021 can be displayed when an error occurs in the developing
rotary.
The detail codes are:
0001: The developing rotary home position
cannot be detected.
0002: The intervals of flag detection during rotation is
too short or long.
0003: The sensor does not detect the flag when the
developing rotary stops at development point
As a result of inspection,
it was found that the DC Controller PCB was unable to control the motor because
it was faulty.
Workaround : 1. Check whether or not the
developing rotary receives any physical load.
Rotate the developing rotary
in a counterclockwise direction by hand to see whether it rotates smoothly. If
any abnormality is found, eliminate the root cause. No problem is found, go to
the Step 2.
2. Make sure that the connectors are securely fitted between J313
on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire.
No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with
a new one. If the symptom still recurs, go to the Step 4.
4. Replace the
Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor:
FM2-0080-000
Canon USA, Inc. Systems & Technical Support Division
