A
Anonymous Posted on Oct 07, 2014
Code for Dish DVR
Onkyo Remote code for dish DVR
5 Related Answers
A
Anonymous
  • Posted on Apr 12, 2008
SOURCE: Dish DVR remote control programming Bose Cinemate
your screwed. jk idk
Anonymous
  • Posted on Apr 16, 2008
SOURCE: Need Remote Codes for Dish Network DVR
Durabrand tv's have three codes they are 623, 220, 221. one of those codes should fix your problem.
Anonymous
  • 14 Answers
  • Posted on Mar 03, 2009
SOURCE: Dish Code for TX-SR806
Dish Network
System
00775, 01505,
01775
Anonymous
  • Posted on Jul 29, 2009
SOURCE: Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Anonymous
  • 146 Answers
  • Posted on Jan 10, 2011
SOURCE: dish remote code for Viore 32" HD LCD
Hi, my name is Cheri Torres and I am with DISH Network customer service. I came across your post and wanted to see if I could help. DISHNetwork remotes have a few different codes for each of our different models of remotes.You should be able to find your remote model number on the back at the top ofyour remote it's usually a two to three digit number with a decimal point. Iwill list here for you the best codes for the most common DISH remotes and alsothe instructions for addressing your remote to your TV. The only codes that I was able to find for the Viore TV were for the 5.3 IR remote and the codes are 563 and 500. If these codes do not work you can also try running a channel scan to find your particular code. I will also list here for you the instructions for running a power scan. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to post back here or email me at [email protected]. :)
Instructions for addressing remote to TV,
  1. Turn the Television On
  2. Press and Hold the TV mode button down until all the mode buttons (i.e AUX, SAT, TV etc.) light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the TV button down until all the mode lights light up.
  2. Press 500 using the number key pad.
  3. Press the pound(#) button once.
  4. The TV button will blink red three times.
  5. Then again press and hold down the TV button down until all the mode lights light up.
  6. Press and release the big red Power button once.
  7. Press the Up button once every second while pointing the remote at the desired equipment. Keep pressing the up button until the TV turns off until.
  8. AS SOON AS THE TV TURNS OFF Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  9. Try the functionality of the TV to see if the power scan worked.
Dish Network
System
00775, 01505,
01775
tip
DISH Solo DVR VIP612 Manual Download
Download DISH Solo DVR VIP612 Manual
Would you like to review the features of the DISH Solo DVR VIP612 ?
Have you lost your DISH Solo DVR VIP 612 Owners Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP612 Users Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo VIP DVR 612 documentation.
I hope that helps.
____________________________________________________________________
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
tip
Changing DISH Solo DVR VIP612 Limited Mode
What is DISH Solo DVR VIP 612 Limited Mode?
To turn Limited Mode on or off, follow these steps:
  1. Press and hold the correct mode button (for example, TV) until all of the mode buttons light up.
  2. Release the mode button.
  3. Press PAGE UP to turn Limited Mode on, or PAGE DOWN to turn Limited Mode off.
  4. Press POUND (#).
Note: Limited Mode is not used with amplifiers (AUX mode).
I hope that helps.
tip
DISH VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
tip
I hope that helps.
on Jul 05, 2010 • DISH Network ViP 612
tip
DISH VIP612 Program AUX Remote Code
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
tip
DISH Solo VIP612 DVR Quick Reference Download
Download DISH Solo VIP612 DVR Quick Reference Guide
Would you like to review the features of the DISH Solo DVR VIP612?
Have you lost your DISH Solo DVR VIP 612 Quick Reference Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP 612 Quick Reference Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo DVR VIP 612 Quick Reference documentation.
I hope that helps.
on Jul 04, 2010 • DISH Network ViP 612
tip
DISH Solo VIP612 DVR Manual Download
I hope that helps.
on Jul 04, 2010 • Televison & Video
tip
I hope that helps.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
