To help you understand to perform factory reset for Nexa Corona 7 tablet, please follow the instructions given below:
- Make sure before performing factory reset, you take all the data backup from the tablet.
- Switch OFF the tablet completely.
- When it is completely switched OFF, press and hold 'POWER' and 'VOL+' together until you see a picture of the android robot lying on his back.
- Tap the 'Power' button once.
- You will see a menu, use 'VOL-' to move down in the 'Menu'.
- When you get to the 6th item (factory reset), press 'VOL+'.
- Do the same on the next screen to navigate to 'Yes' and wait for the time to finish the factory reset.
reset it using the pin hole reset button on back
or You can try a factory reset on the tablet. Hold the volume down button and press the power button. This should bring up a system menu that should have an option to perform a factory reset on the tablet.
To factory reset your tablet - Open system "Settings", then "Backup & Reset", then "Factory data reset". Once reset, all settings will be restored to factory default settings and user will be required to do the initial setting.
1. Turn off the tablet power completely 2. Press and hold VOL - and power at the same time 3. Tablet will turn on and go to the system menu 4. Go to 'Wipe Data/Factory Reset' 5. Press VOL+ to select 6. It will take you to reboot system now, press VOL+ to select. 7. Tablet will reboot and restore to factory.
