I need to access the CD drive where 2-3 CDs are stuck and cannot be dislodged externally. I need to removed the faceplate to get to the CD drive. I have removed the front 8 screws with a Philips head. The faceplate remains in place. What else do I need to do?
I just did this over the weekend, so, I'll expand on how to get there.
1. Pop off the speaker covers.
2. There are 4 screws on each side (not the speaker screws, the recessed screws). Remove those from each side.
3. On the back of the unit, there are 4 more recessed screws. You'll need to remove those, and separate the back from the unit (you may have to disconnect some of the wire connectors).
4. Flip the unit over (so the bottom is up). Remove the screws from the bottom, and remove that base. Note: you'll need to remove all the foot-pads as well (there is a screw under each).
5. Once you've removed that, you'll need to then remove the next set of screws from the "sub bottom" I believe there were 8 that need to be removed.
6. Carefully flip the unit over (you can put the "base" back on without the screws so it sits right).
7. At this point, you'll need to remove the top cover. You'll have to pry away at this one a bit, but it wasn't too hard. There is a connector for the snooze/mute button that I disconnected to make it easier once the cover was open.
8. Once the top cover is off, you'll see the CD player. There are two screws holding the CD player to the faceplate. Remove those.
9. There are three screws on the back of the cd player. Remove those, and you can maneuver the CD player at that point (I didn't need to take mine all the way out, as I just needed to get a quarter out of the player).
Then... gently reassemble. This is not an easy machine to tear apart by any means. Took me about an hour and a half to do it all (but I was also doing some trial and error).
Good luck! And be careful!
