Disconnected hoses, which are clear and flow is strong. what next? thanks
SOURCE: Water Pressure - FH Error
Check first the filters on the inlet water line. Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
SOURCE: Low Cold Water Flow into Machine
the water inlet valve has to be replaced,its the part where you seen the screen ,where the hose hooks up to,theres a cylinoid that opens and closes and lets the water come in,your cylinoid is no good,but you change it as one unit,and its called water inlet valve,easy fix you can do your self,if this helps please vote me a fix ya
SOURCE: no cold water Whirlpool top load washer AP595033
Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
SOURCE: Washer takes about an hour to fill halfway with water
Check the solenoids on the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
SOURCE: Low water flow into washer. Rust-colored grit
Its normally held by two screws with a internay hose fitted to it should be quite simple o replace, make sure you fit inlet Filter too ,will stop dirt going into and damaging the valve in future, may be idea to get hot fill /feed tank cleaned....
