My top load washing machine is leaking from the bottom on the rinse cycle
SOURCE: Water leaks during rinse cycle
My Washing machine is leaking in gearbox.the quality of water is bad (Hard)
SOURCE: Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
SOURCE: GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
