Google Earth Logo
A
Anonymous Posted on Oct 06, 2014
Google earth crashes while opening
Just installed then re-installed GE and it still keeps crashing while opening and telling me that it has encountered a problem and needs to close. Gives me no clue as to what the problem is.
Erin Wood
Level 3:
  • Google Master 652 Answers
  • Posted on Aug 02, 2018
Erin Wood
Google Master
Level 3:
Answers
652
Questions
0
Helped
211189
Points
2583
3 Related Answers
Keith Koene
  • 62 Answers
  • Posted on Mar 30, 2009
SOURCE: Internal error
Uninstall GTalk, make sure your OS has all the latest patches installed, make sure java is updated, then reboot and reinstall GTalk.
Anonymous
  • 46 Answers
  • Posted on Apr 29, 2011
SOURCE: it always crashed my google chrome. i even
I think so, If you have Internet Download Manager installed you need to update it to internet Download Manager version 6.03 Beta.
elizabethryi
Elizabeth turner
  • 68 Answers
  • Posted on Nov 01, 2016
SOURCE: google chrome crashes
Gmail Is Up or Down
2helpful
5answers
Google chrome keeps crashing not sure why
You need to check out all these:
1. Check for Conflicting Software:
- Some third-party software can cause Google Chrome to crash. When this happens, you'll see the message "Whoa! Google Chrome has crashed. It's possible that you have malware that can cause Google Chrome to crash.
- Google Chrome has a hidden page that will tell you if any software on your system is known to conflict with Google Chrome. To access it, type chrome://conflicts into Chrome's address bar and press Enter.
- You can try to fix these crashes by updating, disabling, or uninstalling any conflicting third-party software listed in "about:conflicts" on your computer. Also, take a look at Google Chrome's known issues for specific solutions to resolve crashes caused by some software.
2. Scan for Malware
- This includes malware and network-related software that interferes with Google Chrome. Malware can also interfere with Google Chrome and cause it to crash.
- You can try using Malwarebytes, or other anti-virus software to scan for and remove malware or you can also try searching the web for information related to any conflicting modules listed on the chrome://conflicts page (Windows only), to see if there are other steps you can take to remove malware.
- Many crashes are caused by malware. If you're experiencing frequent crashes, try scanning your computer with antivirus software.
3. Solve Flash Crashes
- We have found that the Flash plugin Chrome includes can cause it to crash in some cases. If you are seeing regular Shockwave Flash crashes, you may want to try disabling the internal Flash plugin and using the standard Flash plugin in Google Chrome.
4. Switch to a New Profile
- Chrome crashes may be caused by a corrupted profile. You can test this by creating a new profile from Chrome's Settings screen. Open the Settings page from Chrome's menu and click Add new user under Users.
- Change to the new profile after creating it and see if the crashes continue to occur. You can sign into Chrome with your Google account to sync the data from your old profile. However, Google recommends you don't copy any files from the old profile folder by hand - they may be corrupted and causing the problem.
5. Fix System File Problems
- Google recommends running the SFC.EXE /SCANNOW program to check for - and fix - problems with protected system files on your Windows system if you are encountering crashes. To do this, locate the Command Prompt in your Start menu (press the Windows key and type Command Prompt), right-click it, and select Run as Administrator.
- Type the following command in the Command Prompt window and press Enter:
SFC.EXE /SCANNOW
- Windows will scan your computer for problems with system files and fix any problems it finds.
6. Hardware issues
- It can also cause Chrome crashes. You may want to test your computer's RAM and ensure it isn't faulty.
· If still problem not solve, maybe you should try these simple steps:
1. Try restarting your computer first. It could be that the computer has just encountered a slight glitch on your system, which is causing things to not work properly.
2. Remove and Re-install the Google Chrome application. Doing this will allow your computer to read the files a lot better and faster, and also repair any damaged or corrupt files that have been causing the issue. To remove the Google Chrome application, first insure that you have another browser, such as IE or Firefox, click "Start, Control Panel, Add / Remove Programs," locate "Google Chrome" click UNINSTALL next to it. When the application loads, select "REMOVE" (not repair). Follow the uninstall process, and restart your PC. Problems uninstalling or re-installing Chrome indicate mal- or spy-ware, which must be dealt with.
3. Remove any extensions that you have on Google Chrome. Although they are a great way to personalize your Internet browsing experience, they are not so good for speed and functionality, as many can cause the application to crash. To remove any extensions follow these steps: Open up Google Chrome. In the address bar type chrome: //extensions. Click Uninstall, or Click Disable if you think you may use the add-on in the future. Restart your browser.
4. Disable plug-ins. Chrome can get bogged down with plugins that you aren't using, also. Type about: plugins into Chrome; it will redirect to chrome://plugins. Disable any that you aren't currently using.
Hopefully your Google Chrome crash problems are gone. Hope it works. Sharing is always caring.
Flash player keeps crashing
Re-install adobe flash player.
Link:
Internet explorer 9 keeps crashing
Hi some times IE 9 is not compatible with the operating system hence
install a new browser like mozilla fire fox or google chrome and it will fix the problem
Hi
Try downloading the latest version for your PC from the link below.
Download the correct version by selecting your Operating System before the download.
support.google.com/chrome/bin/answer.py?hl=en&answer=95346
Also,make it your default browser and make sure your Operating System's firewall does not block this application.
Google Earth crashes on my Acer Aspire
it will require a grafics update or try to go in windows update and manual check for updates and see opcional updates please thanks
2helpful
3answers
Crash
When firefox crashes, it creates a report that explains the crash and possible causes. If your firefox can open the point where you can enter addresses, you could type - [about:crashes] to access these reports. pick the report that is similar to your crash and you can send it to Mozilla Firefox for clarification.
However a series of known issues could be causing your browser to crash; For example, if you have old version of the Google tollbar installed in your firefox broser, it could be the cause behind the crash. Also, if you have the vlc media player plugin installed, your browser might crash when you try to play videos that would play with Windows Media player by default. In addition, if you have Yahoo Messenger installed, trying to aces yahoomail could cause the broswer to crash. And the list goes on. So the thing you could do is try and remember what plugins you could have installed or updated, what software you installed prior to your firefox crashing and uninstall them, or even simply disable them for a bit. In addition, check and make sure your Anti-Virus is really up-to-date and that A full scan happened most recently. Malwares are prone to causing random computer behaviour
Screen goes blank when Google Earth globe starts zooming in
Update video card drivers from the manufacturer website. Update direfctx.
I computer crashes when I try to open Google Earth
It's your graphics chip and memory I'm worried about and whether you have shared graphics memory coming out of that 1.49GB, since you "meet" the Display Requirements and really should exceed them for some functions of Google Earth.
Upgrade your graphics board, cause you may just be squeaking by with only 32MB, as 64, 128, 256, and 512MB have been de rigeur for years now.
Top Google Apps Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Google App Expert? Answer questions, earn points and help others
