Sounds like the fridge is trying to start low clicking noise. Freezer is not working at all
SOURCE: Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
SOURCE: candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
SOURCE: servis fridge freezer
Try to unplug the unit to reset the error, but if the error persist please call a qualified technician.
SOURCE: ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
SOURCE: servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
