Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Oct 06, 2014
How to delete newsfeed from tango on ipad
Cannot find a way to delete newsfeed from tango app
1 Related Answer
Jim Thomson
  • 1099 Answers
  • Posted on Jan 05, 2012
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
1helpful
How do I delete books I've already read on my IPad in my Kindle app?
How to delete books from the iPad's Kindle app
  1. Start the Kindle app.
  2. Tap "Library" in the toolbar at the bottom of the screen. ...
  3. Find the book you want to delete from your iPad, then tap and hold the cover.
  4. In the pop-up menu, tap "Remove from Device."
Jul. 19, 2019
How to delete books from your iPad's Books or Kindle app ...
Facebook does not allow my newsfeeds to come in on ipad you see blurry in back ground and cant open my messages on facebook
  1. First of all, you must have messenger app to open your messages
  2. try closing the app, restarting your ipad & re-open the FB app again.
  3. Uninstall app & install a clean version again
  4. if above didn't work; you can use safari to open your FB account as if you are opening it from a desktop/laptop
1helpful
3answers
How to delete apps in iPad
On the homepage of your iPad > find the app you want to delete > long press it until it wobbles > press the cross on the top-right of the app to delete it.
How to delete unccessery apps on a iphone 4?
Tap and hold on the app icon until it wiggles. Tap the X at the corner of the app to delete. Answer the "OK to delete" question. Repeat for other apps. When done, tap the Home button to return to normal operation.
Remove baidu from iPad
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
1helpful
How to delete my recent call on tango ipad
Go to recent call log and remove the calls from there.
3helpful
How to delete apps
You can either delete them from itunes when you plug in your ipad click on the devices and select your ipad then under the tab app you can then choose the apps you want to be on your ipad. Or on your ipad itself press your finger onto the any of the apps until they start shaking on screen the ones you can delete have an"x" in the top left hand corner of their icon, you then click on the "x" and it will then ask "Delete app, Deleting "app"will also delete all of its data" then select delete or cancel. Once you have deleted the apps you then press the home key to start using your ipad again. Hope this helps, if it does please give me a rating.
14helpful
2answers
How to empty trash on ipad
When you hold down on the app icon and it shakes with a little x in the left corner, that deletes an app. Once an item is deleted that is it. There is no trash can like on a mac.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
