Onan Marquis Gold Quiet Gas Generator 5500 Watt by Cummins Onan Logo
L
Lenard Bruan Posted on Oct 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Surges and stops while motorhome is in motion.
Runs ok when park, til it start to move then it surges couple times then it stops. Then trying to re-start having a hard time.
rcbeltz
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Oct 06, 2014
rcbeltz
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
41862
Points
281
Is this gasoline or propane fueled?
I have a 1991 alegro motorhome the gear shift is stuck in park
Often the shifter will be hard to move if the vehicle is on a slope and there's extra pressure on the parking lock up. Try pulling or pushing the RV to remove pressure on drive train and see if it shifts.
Feb 13, 2017 • RVs
93 Georgie boy Cruisemaster motorhom 93 Georgie boy Cruisemaster motorhome stuck in park i 93 Georgie boy Cruisemaster motorhome stuck in park any ideas on how to fix
As with most cars and trucks, if the shifter won't move out of park, one possible cause is a faulty brake switch or shift lock solenoid.
If the RV is on flat ground and the park pawl is not under heavy load, you may be able to shift out of park by unlocking the steering wheel but not turning the key to the on position. Make sure the parking brake is set before you try it.
2answers
I have a grand caravan sport 2003 and recently the car shut down on its own while I was stopped. Started it and it all went well for like 3 hours when I parked infront of a store and it did it again. 5...
Did you by any chance get gas before this happened? If you overfill your gas tank sometimes it affects the engine but when the gas goes down some in the tank everything normallizes
My car surges at idle in drive position
Clean the airflow sensor. There is a special spray to do this. DO NOT use carburetor cleaner. It will damage the sensor.
Fan doesn't run while in idle and begins to over heat until I start driving agin then it cools back down to normal. Also the fan runs when engine is off and drains the battery.
The fan is only supposed to come on when there is excess heat .. in normal driving conditions it doesn't start. When you start your car in the morning the fan won't come on because the engine is cold.
With a hot engine - and it depends how hot the engine is - the fan will only kick in to prevent overheating. In heavy slow moving traffic or a traffic jam, the fan will kick in if needed.
The air flow through the radiator is usually sufficient -in normal driving conditions - to cool the engine.
When you park up and the car has a hot engine, the fan will kick in. This is perfectly normal. It is caused by a surge of hot coolant triggering the fan sensor. Perfectly normal.
The fan then should cut out after a while .. maybe 2-3 minutes at the most. If the fan runs continuously that suggests a fault in the temperature sensor switch.
Next time - wait by the car and see how long it takes for the fan to quit after you have parked up. It should stop of its own accord after a couple of minutes.
If the fan cuts off after a short while, and your battery is becoming drained, that's probably a battery or alternator fault.
Remember: when you start the car the fan won't kick in at idle speed because the engine is COLD, and there is no reason for the fan to start up ..
The fan WILL kick in for a couple of minutes after you have parked the vehicle and the engine is hot
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Auto trans when hot don't wont to shift RIGHT!!!
did it change gears before you change the motor
Top Onan Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
