Televison & Video Logo
r
richard hathaway Posted on Oct 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
<!-- from fixya rte -->Take out of service mode in normal mode - Televison & Video
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Oct 06, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986515
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
My bush 37 inch tv is stuck in configuration mode
You have to set it to normal mode, be service mode option. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
I have a pansonic tv model no TH-37PG9U,that seem to set on hotel mode,how can i reprogram it to get it to even use has a monitor,or to play game on it
You have to set it to normal mode; before to select its inputs. To set it to normal mode, you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
2answers
I have a roshan TV,I tried to change the channel this morning and FACTORY came up on the screen n now I can't change the channel r do anything onthe tv...rs17-8895m
The TV is now in Factory Mode [Service mode] state. You should release it, to normal state, to get normal picture. If you wish to get some details; check the site linked here. Pull up older posts.
Sansui Chic Classic 250 TV
Before entering service mode, be sure that the entire button on the remote control will work properly, if anyone found inoperative, do not use it to enter the service mode. If it is a universal remote control; check it well. With most universal remote controls, sometimes, all the button functions might not work as it should be. If so, try to set it with another set-up code said for your device, and then make sure about its working. I strongly recommend you to use the original remote control to enter service mode.
This is because;
Suppose you have to enter the service mode to adjust certain parameter. You haven't made sure that all the function of the remote control will work properly with your set or not. After entering the service mode, as you know, limited buttons on the remote control will be active. For example, in service mode, channel Up, Channel Dn, Volume Up and Volume down, and the OK button, Power button and Numerical buttons are used to adjust the data parameter. After adjusting all these parameters; you have to come out from the service mode to Normal mode. Otherwise, you can't operate the set. Suppose, the service mode procedure tells you that, you should press the Power button on the remote control to Power Off the set, to come out from service mode to normal mode. Power down the set by its main power button won't make it to normal mode. If the power button on the remote conrol does not work, how can we come out from service mode to normal mode? In fact, you can't come out of service mode.
The most important thing to note is this. Before you attempt to enter the service mode option, read and understand all the instructions. Be sure that there is enough detail to Exit from the service mode. If it is not there, never enter the service mode. For some sets, there will be no Exit option. To such sets, Power it OFF by the main power switch will do the same. But you should make it sure by reading the instructions.
For your information, I've included some set-up codes too here, to check with your universal remote control, if the present set-up do not work with all the functions it supposed to be. Set-up a universal remote control is a trial and error procedure. You might have to check with many set-up codes, before you get a proper code to your remote control to work properly with your set. The included codes are the common codes works for your brand. If you wish to get more set-up codes and set-up procedure, visit the sites linked here.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
You can get more details by this site too.
http://electro-medical.blogspot.com/
After enter the site, just type in the brand name to your set; in the search box, at the top right of the display window; to get gathered the related pages that contains details. Please do not press the 'Enter' button, after type in the brand name into the search box. The search will start automatically, as you type in the brand name into the search box, and will list related pages.
Why my t.v writes factory inthe screen and cannot turn to AV
Now your TV is in factory adjustment mode otherwise called a service mode. you should get out from it, and to go to normal mode, for all other function to work. For that, you have to know about how to enter, and how to exit the service mode. As now the TG is in service mode, you have to look for how to exit from it, and to set it to normal mode. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name and type of your device, in the search box [at the top right] of the home page; to get the related posts easily.
1helpful
What does a timeout message indicate
Timeout:
Your pool service company or somebody (?), had bypassed temporarily the automation, and placed the system into a "Timeout" mode. Not a major problem at all, and normally nothing to worry about! Unless nobody did this and it is in this mode for more than 3 hours. Let me explain briefly...
What does this mean?
Time out is simply a manually entered mode, that will bypass automation for only 3 hours, and will return to normal "Auto" mode after those 3 hours.
Why is this function available?
If your pool service company arrives and the automation system is normally on "Auto" mode, and he or she finds that everything is off, not scheduled to come on yet or just had completed its normal cycle, the service company is somewhat out of luck if, lets say "Muriatic Acid" is to be added, or an "Algaecide" or some other Specialty chemical that needs the water to be circulation for a few hours after adding this product. What can the service person do, if no one is home to reprogram it or to turn it on? He/she can put it into "Service Mode", which is another mode available on an Automation system, but that overrides the system completely and will stay in that mode until it is once again manually changed back to "Auto" mode.
Timeout - is the mode the service provider will use, after using possibly service mode to turn the filter pump on so the pool can be vacuumed, then if a product like what was mentioned above is added, the system can then be manually placed into "Timeout" and the pool pump will run, mixing the chemicals in the pool, and then will automatically revert back to auto mode 3 hours later. Completing the job of diluting & mixing whatever the pool service provider added.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
How to get to service mode
1. Press the Clear Mode key. 2. Use the keypad to enter “107”. 3. Hold down Clear/Stop for at least 3 seconds. 4. Enter the Service Mode. To enter the Normal Service Mode:
2helpful
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
