HTC Droid Incredible Cell Phone Logo
A
Anonymous Posted on Oct 06, 2014
Repair power dock for htc cell phone
Prongs broken at power plug in
Molly McCaughey
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 70 Answers
  • Posted on Nov 26, 2014
Molly McCaughey
Expert
Level 2:
New Friend:
Greenhorn:
Answers
70
Questions
0
Helped
9383
Points
101
Call your service provider
1 Related Answer
Anonymous
  • 1382 Answers
  • Posted on Jun 20, 2010
SOURCE: unlock htc 8925 cell phone
You can get the unlock code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
Htc id so that i ask question abt my htc cell phone
need to know the exact model but you can follow a youtube guide like this
HTC Sensation Screen Repair
HTC sensation my screen is broken how can i replace it DIY ?
Hi Anir
Yes you can, not easy and if your not comfortable with taking electronics apart I would recommend finding a Cell Phone repair store near you.
Here is a great tutorial on replacing the screen.
I Hope this helps
Philipp
Are all htc one replacement screens interchangable?
HTC pledges to replace your phone's cracked screen for free
In a generous move, HTC will resupply unlucky handset owners saddled with damaged displays free of charge.
http://www.cnet.com/news/htc-pledges-to-replace-your-phones-cracked-screen-for-free/
Has the screen on your HTC smashed, cracked or broken? At Geek Squad, we're manufacturer approved to carry out HTC screen repair, so whatever problem you have with your glass or LED, we can sort it. An HTC screen repair can be done for a phone in and out of warranty.
http://www.geeksquad.co.uk/services/repairs/mobile-phone/htc/screen-repair
My htc rhyme power button is broken and the battery died. I charged the phone but have no way of turning it on
Sometimes you can:
Remove the battery, plug the phone into a power outlet, re-insert the battery with the phone still plugged in.
Works on some models.
Jan 01, 2014 • HTC Rhyme
Turn off audible alarm when changing towers
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
God bless you
4helpful
4answers
How to turn on the htc amaze without the power button
Dude take off the case like your about to take off the battery out.Check the top of you phone if the left piece of your phone is gold it broken.
How do I connect the HTC EVO 4g docking station to my tv
Your TV needs to have an HDMI or USB plug to be able to do this. Most TV's made since 2008 have an HDMI slot. I'll attach images of both an HDMI and USB plug to show what they look like. Plug the HDMI or USB plug into the slot in the TV and the mini plug into the docking station, then dock your phone. You will need to change the input on your TV to display your phone on the TV.
HDMI: http://fplanque.net/Blog/Content/dev/electronics/hdmi.jpg
USB: http://www.bidanswer.com/uploadfiles/USB(1).jpg
I CANT CONNECT TO IPHONE 4G
Sounds like a broken dock connector to me. Apple might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at iPhone 4G Repair and there is a guide that shows you how to put in the part at iPhone 4 Repair Guide.
Nov 23, 2010 • Cell Phones
4 prong power cord that plugs into back is bent/broken
Don't try using the system as you are at danger of electrical shock - buy a replacement powerpack direct from Bose.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
