Is the switch wired wrong?
Does the switch have 4 wires?
Look at wiring for single-pole timer and see it it applies to your switch
http://waterheatertimer.org/How-to-wire-timers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: how do i install a combination toggle & outlet
If I understand you question (if not please clarify) you have a switch and outlet combo and you have a box with a black and white coming in one side and a black and white going out the other side. Here's the deal the switch side only deals with the black (hot) lines but the outlet needs a common (white) line so there should be two brass posts the black coming in goes to the bottom brass post and the black going out to the light goes to the top. You should now have two silver posts and these take the white lines they are common to each other (electrically speaking that means they are two ends of the same wire to put it simply) In the event you only have one silver post tie both whites to that one. if this was a switch box the two whites would be tied together with a wire nut and shoved in the back.
good luck I hope this helps.
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
SOURCE: I need the wiring diagram
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Testimonial: "This diagram is, truly, helpful. Thank You! "
SOURCE: new Leviton 'lighted, decorative' switch flickers when off
Personally, I've had no practical problem using the standard lighted switches with CFL bulbs but I am willing to put up with the flicker as the switches are in an unimportant area. The reason why they flicker is each CFL bulb has an electronic circuit in the ceramic base so you don't have to install a balast circuit in every lamp and fixture in your home. This is also why they cost more. You are basically throwing away a complete flouresent light fixture when you change these bulbs. Anyway, the reason the switches flicker is that there is a capasitor in the circuit that keeps charging and discharging through the little neon bulb in the switch. I had a CFL bug light on my back porch and when I was outside looking at the stars at night, I kept seeing something out of the corner of my eye. I stared at the bug light for a while and it was flashing every few minutes as the high voltage circuit in the bulb would charge to it's ignition threshold then fire the bulb and start the cycle all over again.
Good luck.
Jeff
