Microwave Ovens Logo
A
Anonymous Posted on Oct 05, 2014
<!-- from fixya rte -->How do I turn the mute off - SpaceMaker GE Microwave Ovens
Plainfield PPG
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 03, 2017
Plainfield PPG
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3482
Points
If your microwave has a "Beep Volume" you can select from "mute" " - level 0, "Low" - level 1, "Medium" - level 2 and "high" - level 3. There is no specific "mute button" but if you have beep volume you can un-mute it.
Daniel Long
Level 1:
New Friend:
  • Posted on Mar 02, 2015
Daniel Long
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3482
Points
I had this mute problem and found that unpluging it for 1 to 2 min. and the problem cleared.
Ge Cafe Over the Range Microwave touch pad stopped making beeping sounds
If the touchpad on your GE Cafe over-the-range microwave has stopped making beeping sounds, there could be a few potential causes. Here are a few troubleshooting steps you can try:
  1. Check the volume settings: It's possible that the volume settings on your microwave have been accidentally turned off or lowered. Look for a "Volume" or "Sound" button on your microwave and adjust the settings as needed.
  2. Check for a mute function: Some GE microwaves have a "Mute" button that allows you to silence the beeps temporarily. Make sure this feature hasn't been activated.
  3. Power cycle the microwave: Turn off the power to your microwave for a few minutes, then turn it back on. This can sometimes reset the touchpad and restore functionality.
  4. Check for error codes: If there's a problem with the microwave, it may display an error code on the control panel. Look in your user manual or search online for information on what the code means and how to resolve it.
  5. Call for service: If none of these steps work, there may be a problem with the touchpad itself. Contact GE customer service or a professional appliance repair technician for assistance.
1helpful
How do i turn off the sound on a Hamilton Beach HB-P90D23AP-T3B microwave
To mute your microwave, start by checking the control panel. Look closely. The mute function may be labeled as a secondary function of one of the standard buttons. Check these things first:
  • Look for a Sound button. Seriously. It may have been there all along, begging you to press it.
  • Press and hold either 1 or 0. Sometimes manufacturers give these keys hidden, secondary functions.
  • Press and hold the Stop or Cancel button. Like 1 or 0, this key might have a hidden function when held.
Often, pressing and holding 1, 0, Stop or Cancel will either result in turning off the beeping sounds or activating a child lock feature. (Child lock doesn't actually lock the door, but instead locks the control panel so no buttons can be pressed until the lock is removed by holding the button for around three seconds again.)
If none of these work, it's probably best to consult the manual. Even if you don't have a Sound button, there is no Mute function denoted as a secondary function or holding a button doesn't do anything, there is still a chance a mute function exists. It could be a button combination or, like on some microwaves, be buried in a submenu that's not at all obvious how to activate.
2answers
My Avanti microwave keeps beeping nonstop.
Hi.
If you've tossed the owner's manual to your microwave, check the manufacturer's website. They will often provide a digital version of the manual as a PDF for more recent models. For an older model, you may need to do some digging, but a great start is to just do a Google search for "[microwave brand and model number] manual."
Once you have the PDF version of the manual, press Ctrl + F on Windows or Command + F on Mac to search the PDF for "mute," "sound" or "beep."
Good luck.
How to mute the beep on a Hamilton beach microwave. Or is there even a way to completely mute it. If not then is there a way to turn down the beep volume
unplug machine. you will need to remove the cover. careful for the capacitor. usually after not running for an hour or so the capacitor will completely discharge on its own. looking at the back of the control board, you ill see a small round, usually black cylindrical part about 1/2 inch high with a hole in it. cover the hole with a couple small pieces of duct tape. this will mute the daylights out of it. to eliminate sound completely you will need to unsolder this part..
How can sound be muted on ffcmo934ls a Frigidaire microwave oven?
I appreciate your inquiry, friend!
From what you have described you would like to mute the sound on your Frigidaire microwave, FFCM0934LS. I have researched your microwave and I was unable to any instructions on how to mute your sound. Unfortunately you are unable to perform that operation on your microwave. I hope this is helpful information. -Matt
Whirlpool X2-20ES
If it's possible to mute or turn down the volume, the owner's manual will cover it.
If not, you may want to take extreme measures, as shown in the video.
1helpful
Disable buzzer
Beneath the time on the clock. The word "mute"
I have 2 possible solutions for you.
1) press and hold the 0 button for 3 seconds. This may only turn the clock display on or off, but may also mute or unmute the beeps.
2) unplug the unit for 30 seconds to a minute. Plug it back in and it should be reset.
RVM1335WC 001 - Mute turned on and I don't know how to turn it off
Unplug the microwave for 15 seconds than plug back in. It should be back to normal then.
Turn off beep?
No. Not unless you are willing to tear the thing apart and do some electronics work inside.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
