Dont know your model but usually things work that way. If your remote is on cable box function then is used to change channels on your cable box. Once you switch remote to tv mode then channels function is used to switch channels on tv. Tv must to be either in over the air tv (antenna) or unscrambled cable channels if your tv is equipped with internal decoder
Some channels are scrambled on purpose by cable companies. You have to pay for the channels that you want, and then and only then, the channel is unscrambled.
It depends with which digital receiver you own. If it is a free to air then you will need a firmware to unscramble https://surpex.ecwid.com
But if it is subscription receiver then contact your service provider or use the software above at your own risk.
https://surpex.ecwid.com/
Make sure you are using the correct channel on your capture device and/or on your VCR.. Once upon a time VCR's used to only work on channel 3 or 4. There should be a toggle switch in the back of your VCR that will say Ch.3 ' Ch.4. Then check the software on your capture device also. One more thing. Some tapes have a copy protection on them which can do a number of things to trip up what you are doing. If you are sure everything is correct, double back and recheck. Then look into a decoder/unscrambler for VHS. Should be a simple Co-Axile pass-through with a frequency modulating knob on it.
Try H & Y electronics. Thats www.hyelectronics.com
They carry ANY and EVERY CB antenna that is avaliable on the market. If you dont like ordering on line, try your local Truck Stop. They also carry lots of CB antennas. Hope this helped. Lost Jeep, Athens GA, 10-7 !!
I have a eurovox pvr ex5000 box. The channels got scrambled about 2 weeks ago. Do you know the new codes that I need to put in, for the channels to unscramble?
