Question about Mercedes M-class Ml Ml350 Ml500 Ml55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2003 2004 2005
Will a crank shaft ignition sensor keep a car from starting?
  • Mercedes-Benz Master
  • 3,506 Answers
Yes if it is defective or missing
Posted on Oct 06, 2014
SOURCE:
2001 Honda Civic car starts and runs fine ,after turning off ignition car would not crank or start only after 20 to30 minutes car would crank and start
Hi there I am technical mechanical and electronic engineer mechanic it need a new ignition switch or ignition lock n key
Oct 25, 2015 | 2001 Honda Civic
My 1993 jeep cranks but won't start. Help!
-Couple things that cause a car not to start.
-Low fuel pressure, faulty crank shaft , cam shaft sensor, bad
ignition module, weak coil. (spark)
Good Luck
Mai Lor
Nov 08, 2014 | Cars & Trucks
My 95 Jeep Grand Cherokee keeps shutting off while driving. Sometimes I can put it in neutral and restart the engine while rolling. Most times, not. After 5-10 minuets and as many times cranking, it will...
54 - Sync Pick-Up Signal Not Detected (Camshaft Position Sensor/Ignition Pickup). recheck to see if power to sensor. make sure wire is in good shape, to cam sensor. 11 - No Crank Reference Signal At Power control module, crank shaft sensor. check to see if your getting signal from pcm. Good-day!
May 20, 2014 | Cars & Trucks
P1374 code on 2000 chevy venture
This a code for ignition system The 3x pulse is not being received from the crank shaft 18x sensor Very complex testing to correct this problem. Ignition module and crank shaft and cam shaft sensors must agree for the computer to control injection timing and spark advance
Apr 28, 2014 | 2000 Chevrolet Impala
Car would not start, after siiting for an hour it did start .
mcdevito75 here, BEST BET, let the shop do this work, too many un forseen problems could come up. The stalling and unable to start for a while could also be a bad ignition module, no test for this part, but I would have it changed, for if it is a bad ignition module, all this other work will not fix the stalling and later start of your car.
Feb 27, 2010 | 2002 Kia Sedona
Truck keep cutting off on the road,i have replaced the tps sensor,crank sensor,ignition coil
try checking your ignition switch sometime they might go back
normaly its just the crank shaft sensor, make sure you get the right one for your engine.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Oct 07, 2009 | 1998 Jeep Grand Cherokee
No spark no FI pulse NO START
Check the ignition switch please. Had that on a 93 Ford that it was bad and the coil wasnt getting any electricity while the switch was in "start" position.
Aug 17, 2009 | 1994 Ford Escort
2000 Pasat Engine Cranks but No Fire
likely crank shaft sensor ,maybe fuel pump or cam shaft sensor ,ignition module under coil pack,check your codes as your first effort in this,
Aug 16, 2009 | 2000 Volkswagen Passat 4Motion
Will not start changed the crank shaft sensor will not start changed the crank shaft sensor still nothing injectors wont go to and no spark any ideas please
It could be a computer malfunction or a circuit in the ignition switch has went on you. By the description I get that the spark plugs and the injectors are not working?
Jun 10, 2009 | 1997 Dodge Caravan
Car cranks but won't start. Diagnostic code says
I changed all the parts I mentioned and finally I decided to try the crank shaft sensor and if that didn't work I was going to replace the cam shaft sensor. Luckily the crank shaft sensor worked but only after I replaced all the other parts. But at least now it finally started.
Thsank you.
May 17, 2009 | 1997 Dodge Grand Caravan
Mercedes M-class Ml Ml350 Ml500 Ml55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2003 2004 2005 Logo
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
