Question about Razor E300 Scooter
The battery is charged but it only clicks when I try to start it
97 jaguar xj6 no start with clicks...tried to charge battery w trickle charger
the battery could be so died that it will not charge and cheap cable will not carry enough amps to start it
Oct 01, 2012 | 1997 Jaguar XJ6
2003 Ford Taurus will not start. Have tried jumping the battery but still nothing. When turned on, all dash lights come on and then there is a click sound when we try and turn it over.
2003 taurus not starting the lights on dashboard not coming on.windows wont go up and wont crank ..anyone know what to do ..please
May 14, 2012 | 2003 Ford Taurus
My car make a click click sound when trying to start
That sounds like a flat battery. Lights and horn working are not a true reflection of the battery condition. If the dash lights dim while you try start the vehicle, it is definitely a battery low on charge. Have the battery charged or replace it and have your charging system checked out. With the engine turning at about 2000 rpm, a volt meter across the battery should read about 14.5 volts. If it is much lower than that there is a problem with the charging system.
Jul 13, 2011 | 2002 Cadillac Deville
Battery was dead and tried to start after charging, starter solenoid clicked and engine turn over slowly without starting. Now engine will not turn over. Battery is charged have power to all accessories...
okay,think of it this way,you tried starting,engine turned slowly,no start.....then you charged battery,engine wont turn over(although accessories work)WHY WAS THE BATTERY DEAD TO START WITH.Try a jump start(another battery)if it starts then you know what im going to say.....
Nov 06, 2010 | 2005 Ford Explorer
My car just clicks when I try to start it but it doesn't start. It will jumpstart but once I turn it off it want restart
Hi!!
The clicking sound is a sign of a drained battery. Check your battery cables for loose or corroded terminals, if everything OK, jump start the vehicle and take it to an AutoZone, Checkers or similar auto parts store to have your Starting/Charging System checked. They perform this test free of charge.
Good Luck!! Don't forget to rate this post!!
Sep 21, 2010 | 2008 Ford Fusion
Batterie died after trying to jump start it my car was dead i plugged it in to charge i turn the key and the lights work the car wont even click over when turned ignition to start
Make sure you have the car properly in Park with lights off and try. If there's no clicking you either have a very loose terminal on the battery or the battery is no where near charged up enough. Try to jump start with someone wiggling the wires for the jumper cables. Once it starts clicking, leave the wires alone and let the battery accept a charge about 10 minutes while the other car is hooked up and then try again.
Sep 16, 2010 | 2003 Kia Spectra
Go to turn the vehicle on - where the dash lights all light up - then turn to start the truck and things go blank - then I start hearing these "click" "click" "click" sounds
It sounds like what you need to do is check your batteries. Clean the cables and terminals very well, then tried again. If it still won't start your battery might be dead. Jump it or charge it and tried again. If it starts but later I will not start you might have a charging system problem or a bad batteries.
May 26, 2010 | 1999 Dodge Ram 2500 4WD
Bike won't start
Try rechargeing the battery, it sounds like it might take a charge but not hold it. The click is probably the solenoid trying to kick the starter in but not having enough juice to manage it.
If you can get the battery to take a charge and the bike starts, but the problem repeats itself, replace the battery. If you can't get the battery to take a charge at all, replace it or have it tested at your local service station.
Good luck.
Mar 30, 2010 | 2006 BMW R 1200 RT
Electrics
in fact only turned over once befors starter was clicking away. Pushed it home tried again - nothing. Put battery on charger - charged up in 15 minutes - tried to start - engine turned over couple of times then click click click at starter been out this morning checked all connections and earths - charged battery up - read 13.22v when full charge light came on, tried to start up - turned over several times, getting slowwr then click click. Checked battery reading 12.17v Any suggestions - is it the battery or what else?,The fact that the voltage drops as the revs increase is very odd. However, the dash voltmeter which I assume you are using is often inaccurate. Try an alternative battery, at least to see if it starts. You could use a car battery with jump leads. With a decent battery the charging might improve too.,,,
Nov 10, 2008 | 2002 Moto Guzzi California 1100 EV Special...
Electrics
Razor E300 Scooter Logo
292 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
