Maytag Bravos MTW6600T Top Load Washer Logo
A
Anonymous Posted on Oct 05, 2014
<!-- from fixya rte -->Washer wont spin. F51 code - Maytag Bravos MTW6600T Top Load Washer
Richard Roth
Level 3:
Top Expert:
  • Maytag Master 9,472 Answers
  • Posted on Nov 26, 2014
Richard Roth
Maytag Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626548
Points
28464
The f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
1 Related Answer
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Dec 19, 2010
SOURCE: I have a Maytag Bravo
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Please, in my washer appear the code F51. What is it? What is the matter in my washer? Thanks
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa!!
Leaking and F51 error code on my Kemore Elite Oasis Washer
Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Code f51 on my kenmore oasis washer. What should I do
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
2helpful
Kenmore Oasis F51 code - already replaced RPS. Now what?
3helpful
F51 code appears and stops the washing cycle.
6helpful
Kenmore elite toploader code f51
1helpful
F51 code
F51 comes out and the machine stops working. what can i do
6helpful
F51 code
Washer wont spin or wash
F51 trouble code is the washer sensor. Try unplugging the system for 1 minute then plug back in and see what happens =. If that does not work then open the back of the washer by the knobs and in the middle there are 3 sensors check which one has a burnt mark on it and replace it. Other thing is to call Kenmore and see if they will come out and replace since this is a VERY serious problem.
If you are satisfied with my answer please raate
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
