Question about Electrolux Band Aerus Lux Legacy Canister Cleaner
Electrolux canister keeps stalling when attachments are placed on hose
Vacuum starts and stops when the hose assembly is moved.
Hello, it sounds like you make have a wire loose in your canister. The canister needs to be repair by a qualified repair person due to shock hardzards.
Oct 27, 2015 | Kenmore Canister Vacuum Cleaner,...
How can I extend the hose so I don't have to bend so far down when I vacuum. I am tall
You could try wearing the cleaner like a backpack...
I live in a small town and there are at least two businesses here where I could buy vacuum cleaner hose by the metre.
I have also seen purpose-made 1 metre hose extensions.
It isn't always easy but I have repaired and replaced hoses, changed ends and generally managed to use surplus and discarded hoses rather than buy new.
I suggest you approach the sort of business that supplies vacuum cleaners and washers and suchlike to other businesses rather than a high street type shop.
Feb 25, 2015 | Miele Olympus S2120 Canister Vacuum...
Can't open vacuum bag compartment
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Nov 10, 2014 | Electrolux Aerus Lux Guardian 9000...
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Have a lux legacy c 153c made by aerus comes on and runs fine for maybe 90 sec then shuts off and in about 90 sec will come back on .has great suc and runs great while runing
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor.
I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off.
Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops.
I hope you post what you find out!
Jul 28, 2014 | Electrolux Band Aerus Lux Legacy Canister...
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Jul 22, 2014 | Electrolux Band Aerus Lux Legacy Canister...
How do I remove & replace carry handle?
Refer this issue directly to Electrolux for guidance in replacing the handele.
Jan 25, 2014 | Electrolux EL6988E Oxygen Canister HEPA...
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
Sep 25, 2013 | Electrolux Band Aerus Lux Legacy Canister...
Reset buttton location
The reset button for the power nozzle in on the top of the housing just to the right of the wand to tool connection. As for the tank; this is more a guess than an answer: There is a small hole at the bottom of the bag compartment. I wondered if that was a reset button, but the manufacturer recommends disconnecting the machine until it cools down and resets itself.
I know it is not much help. Electrolux Aerus does not want customers to repair their own equipment, and they will refuse to give out information.
Jan 15, 2013 | Electrolux Band Aerus Lux Legacy Canister...
Electrolux Band Aerus Lux Legacy Canister Cleaner Logo
65 people viewed this question
Top Electrolux Air Purifiers Experts
ray gallant
ray gallant
Tom Chichester
Marvin
Marvin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
