SOURCE: The stand by timer flash 9 times stop and start again
you have a regulator problem my friend in the power supply or there is a fault in the G board. This is not a repair an untrained person should attempt, please get a pro to assist you in this repair.
SOURCE: kv27fS100 - LED BLINKS 15/16 TIMES FIRST AND THEN 2 TIMES CONTINUOUSLY
The initial blinking is normal. The two blinks are the key and indicate an over current condition detected. This can be a problem in any of the circuits. Since the set initially performs as expected and the blinks show up after a little while suggests that the problem is in the high voltage circuit. If you are comfortable working inside the set, check the horizontal output transistor for a shorted condition. That is the most common failure. If you must see a servicer, expect a parts cost in the $25 range. Add in the local labor rate for the total repair cost.
Dan
SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
