Car want start due to me trying to start it, while it was already running
You said it won't start, but what do you mean by that? ie..It cranks, but not start, or the starter doesn't spin at all? If the starter spins, you should check to see if you still have an ignition spark to the spark plugs. If not, you could have blown a fuse or even fried the computer, but not likely. If it doesn't spin at all, you may have damaged the starter or burned the ignition switch.
Possible bad starter solenoid, replace.
