SOURCE: My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
SOURCE: the dehumidifier is running all the time but not
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: just purchased a Danby dehumidifier
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
SOURCE: I have a DDR7009EE and the fan runs continuously
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
