Inserted new filter. Cannot get system fill to work. Press button and crunching noise. No water moves through to fill the system and message remains.
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
SOURCE: Jura z5 after filling system said coffee ready
Someone online sells a special screwdriver head used to open the Z5. With it, it's possible to take the machine apart, clean up the coffee ground dust that gums up the moving parts. You can giggle sensor switches that get stuck. The water lines will need decalcifying eventually, even if you use the the Clearyl water filter cartridges. If you're not up to taking machines apart, sell me your broken Z5: [email protected]
SOURCE: How do I fix our
Press the button to the right of the function wheel that should be lit, this will then purge air from the water pipes and fill the boilers, the unit should then operate as normal.
SOURCE: Changed Claris Filter-now says "fill system/press steam"
I have had an S9 for 8 years now and have had it refirbished twice in its lifetime. I am convinced that the Claris Water filters cause this problem in that they can creat to much resistance or air and the system becomes water starved.Try taking out the filter and running steam for a couple of minutes. If you see water coming through, you most likely have a bad filter. moving forward, i am leaving the filter ourt and running the system in the DeCalc mode. I will have to decalcify the system routinely now but its worth eleviating the filter headache.
SOURCE: Hi, our Jura Impressa Xs90
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
