Question about MSI Computers & Internet
I recently purchaced a gaming laptop (msi GT70 2PE) and the usb 3 ports arent working as they should. I get tops 16mb/s write speed when copying to a data traveller kingston g4 usb stick. All drivers
I recently purchaced a gaming laptop (msi GT70 2PE) and the usb 3 ports arent working as they should. I get tops 16mb/s write speed when copying to a data traveller kingston g4 usb stick. All drivers are installed correctly but is this normal? do i need maybe a bios update or a special setting?
  • Billy Billy
    Billy Billy Oct 05, 2014
    The ports are normally identified by win 8.1 as usb 3 ports.
  • MSI Master
  • 10,543 Answers
Check the write speed specs on the thumb drive.They are not all the same.
Posted on Oct 05, 2014
SOURCE:
myob247
  • 1342 Answers
SOURCE: usb ports quit working in gateway laptop
This article references a Dell computer but maybe it'll work for yours.
Posted on Jul 04, 2008
SOURCE: Acer Travelmate 3200 usb dont work
sir my name is ayaz ahmed  im  system administrator in quetta textile mills limited in karachi pakistan please solved my problem  thanks  best regard ayaz ahmed
Posted on Aug 20, 2008
  • 188 Answers
SOURCE: t40p usb 2.0 ports acting like usb 1.0
There is no hardware or software fix for this. Here is a thread on what might be your problem. http://forum.thinkpads.com/viewtopic.php?t=67571
Posted on Sep 25, 2008
  • 170 Answers
SOURCE: acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process. http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
Had the same problem with my Dell Vostro, sent it to aqstech.com they did teh repair for $99 + shipping. Cheaper than a new laptop.
Posted on Jun 15, 2010
Why wont steelseries recognise the laptopkeyboard???what do i do???
So, start out with plugging your keyboard in. Where do you have it plugged? It may be "USB 2.0", and if you have it plugged into a "USB 3.0" socket, it may not work. Try a different socket.
Try a different computer, perhaps the keyboard is bad.
Try a different keyboard, too.
Oct 02, 2015 | MSI Computers & Internet
Have a LN40D630 LCD Samsung TV. has transparent whitish block of horizontal lines across the top of the screen about 3" from the top down. The lines look like they are on top of the picture and are
AmanStino 3 USB Ports Car Charger with 1 Type C Prot
  • Input: DC12-24V.Output: DC5.0V 10.2A (3X2.4+3A).
  • High Speed charge for Apple and Samsung Series.
  • Extending USB Hub - Allow back seat passengers to easily charge devices.
  • Perfect for watching movies and playing games on long road trips.
  • With a 1.5m cable length,the 2-port HUB allows backseat passengers to easily charge their devices.
AmanStino 3 USB ports Car charger with 1 Type port AmanStino
Jan 28, 2015 | Samsung 40 LN40D630 LCD TV
Why my siyoteam 4 port usb 2.0 high speed hub not working in windows 8 hp laptop. i plug the port into the laptop but it cannot been seen in my pc, is there any thing can i do inorder this usb hub to work...
Perhaps the laptop port is designed for a usb 3.0 insert instead of a usb 2.0? Also try using compressed air to clean both connections. The hub male end and the laptop female end.
Oct 31, 2013 | Universal Genuine SIYOTEAM 4-Port USB 2.0...
Recently, when I insert a USB flash drive into my laptop's USB port, I get the message: This USB device can perform faster if you connect it to a HI-SPEED USB 2.0 port.
Your laptop has USB1 port and the USB 2 message will appear if you plug an USB 2 device into this USB port.
You maybe able to upgrade the USB port to USB 2 if there is a BIOS upgrade available from the laptop manufacturer's WEB site.
If not you maybe able to get an USB 2 PCMCIA card to install into the PCMCAI slot on your laptop.
Dec 04, 2012 | Computers & Internet
Would you know the answer ?
The packard bell easynote h5315 has 3 USB 2.0 ports. The many product reviews on the internet don't say exactly which ones are high speed. Ultimately it doesn't really matter unless you are thinking of copying large files greater than 1GB then it will take longer on a low speed port.
To test this I suggest you put a file larger than 500MB on a flash drive, then plug the flash drive into the first port and copy the file back to your notebook. Take note of the time it takes. Repeat this step with ports 2 and 3. Review the results together, the port/ports that copied the file the fastest are your high speed ports. The port/ports that took longer to copy the file are low speed. If all the ports take similar times to copy the file then all 3 are low speed ports.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
Can x40 connect to wireless broadband? Is the graphics ok for games that are not too demanding? Is it suitable for an 11yr old girl who wants to play games & use skype & internet? USB broadband,...
1) Can the IBM ThinkPad X40 series of Notebook PC connect to a wireless broadband router?
I would plug in a USB wireless adapter that is Wireless N.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076236&CatId=2688
2) Are the graphics OK for games that are not too demanding?
A) Processor:
Intel Pentium M processor, that with the highest option model, operates at 1200Megahertz. (1200MHz)
B) Ram Memory:
512MB's of PC2700 ram memory. (DDR Sdram at 333MHz. SO-DIMM ram memory)
C) Graphics chipset:
Intel 855GME chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4-M.2FPentium_M.2FCeleron_M_Mobile_chipsets
Like a slug crawling along in deep winter.
USB broadband, and USB mouse?
Sure.
Enough USB ports for this? There are 3 USB ports.
My recommendation is No, sir, or ma'am.
Hate to rain on a parade, but kids expect the laptop to perform gaming on top level, connect to the internet at lightning speed, and pour a soft drink at the same time.
(Kinda of what we adults expect)
She'll be bored with this laptop in a day.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 21, 2011 | IBM ThinkPad X40 Notebook
How to copy the pc game to usb port?
1. You have to extract the ISO or MSI or DEB image of the game into a PC. You can get this software freely available in the net.
2. Then you have to use a USB installer software to burn this ISO image into a USB drive. USB installers are also freely available in the net.
3. Then you can used the USB drive to install the game into any PC/Laptop
Aug 12, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi, My maxtor hard drive is not working anymore. Every time I connect it to a USB port on a laptop/desktop I continually hear a clicking sound and nothing happens. It does not show up in "My...
the symtem which you explined is confirm that the HDD is deffective but still you can replace the USB cable. check the supply is proper or connector if external supply is their.
you can aproch data recovery centers which are available in your area
data recovery software is available, that also you can try
I hope your problem will solve
let me inform
Apr 07, 2011 | Maxtor OneTouch III 500GB 7200RPM USB 2.0...
Is my problem the internet signal or the wireless router?
Howdy,
If you have been using this router/laptop for 3 years successfully and then all of a sudden it does not work, you may attempt to try an external USB wireless adapter. Does your T30 have 802.11b connectivity built in? It is not unusual for these to go out. Before you buy one check first to see if you can still access wirelessly at other hotspots? Or does the problem follow you around? If you can successfully connect at other hotspots then this is not the problem and it may very well be your router. Is there any way you can get a substitute rouer to test with before you purchace one? A friend maybe? It is probably one of these 2 issues. If you find your wireless is out on the laptop and you go to purchace a USB wireless adapter, go for a Linksys and make sure it is at least wireless "g" or "n" and not "b". And if you do not have enough USB ports then you may want the flat wireless card adapter that plugs in to the PCMCIA slot on the laptop. This can be Linksys also - I use this one (flat card) - "Wireless G Notebook adapter with SRX" Model Number WPC54GX. It is great and has speed boost. If your built in wireless on the laptop is bad, then any of these external adapters you choose to use will simply take over the wireless reception. Good Luck.
J
May 30, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Mecer Laptop USB port not detecting
Reset the Bios.That solved the same problem i had.
Aug 30, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
